Author Topic: Next Step  (Read 2132 times)
Offline GolfChick24
Next Step
« on: 18 August 2005, 17:38 »
Ok the dash is off, okay the clocks are off now how do i go about getting into the clocks with that blue paper stuff on it? I was gonna ask a certain gorgeous bloke  :cool: but he disappeared. Are there just the three lights at the back of the clock and how do you go about removing and replacing them? How do you get into the switches to replace them with leds?
Alison
Offline ...joe
Re: Next Step
« Reply #1 on: 18 August 2005, 19:02 »
the little bulb holders just twist out, there are two on top and one in the middle behind the lcd screen, although this has its own green filter so never shines up bright unless you dismantle lots of things to get it out.
you don't need to remove the blue film with the pcb on it (i think). to take the green filter out you have to break out the white section on top as its melted in at several spots then just unpick the filter. if you do have to remove the film, the plug(s) on the bottom slide out then the film is held in place by little pins, just go slow because the copper tracks can be damaged.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline ...joe
Re: Next Step
« Reply #2 on: 18 August 2005, 19:04 »
and .........
1 dismantled switch, should all be obvious how it all goes together:
Offline [han]
  • Graphic Designer for Haribo
Re: Next Step
« Reply #3 on: 18 August 2005, 20:09 »
lol.. i had a go too on the spares, took a screwdriver to it... how much fun.. now i ralise why i ain't allowed to tinker with car on my own!! i broke a nail! argh!!
Offline Dizzie
  • Make friends with your fast
Re: Next Step
« Reply #4 on: 23 August 2005, 23:31 »
dash out - like this? :D
« Last Edit: 23 August 2005, 23:34 by Dizzie »
