Author Topic: Leon cupra r brakes  (Read 3605 times)
Offline Rod1-gti
Leon cupra r brakes
« on: 15 September 2013, 17:57 »
How much do cupra r brakes normally go for? And will they fit under 16" wheels? Planning on upgrading.
Offline brewey
Re: Leon cupra r brakes
« Reply #1 on: 15 September 2013, 17:59 »
Fairly sure you need 18s. The discs are 323mm but the calipers are chunky. As for price I've seen a fair few pairs around the 4-450 mark.
2000 1.8T ARZ - OEM+
Offline dom
  • Back in a Mk4
« Reply #2 on: 15 September 2013, 18:03 »
Bang on, you might get away with 17s but I doubt it. Half decent ones usually go for the £500 mark.
Offline km
« Reply #3 on: 15 September 2013, 18:04 »
Seen them from 400-500.
Bought mine for £400 with discs and pads.
And yeh, biggest problem I've had is wheels that clear the chunky calipers.
Be prepared to buy wheel spacers!
Offline brewey
« Reply #4 on: 15 September 2013, 18:05 »
I think I remember seeing a build thread on ED38 with them squeezed under 17s as a temporary fix but they needed shaving slightly and even then there can't have been more than a hairs width.
Offline rockmonkey69
« Reply #5 on: 15 September 2013, 18:10 »
It will clear fine with 17" depending what wheels. I'm running 17" and my setup is larger than 323mm
Offline dom
  • Back in a Mk4
« Reply #6 on: 15 September 2013, 20:24 »
It's not the disc size that's the issue, it's the width of the caliper. It depends on the offset and width of the wheels, you'll struggle under most 17's without spacers.
I have also read that thread, they did have to grind some of the caliper away.
« Reply #7 on: 15 September 2013, 21:07 »
My discs are larger than lcr disc and my calipers are larger and chunkier than lcr calipers
Offline dom
  • Back in a Mk4
« Reply #8 on: 15 September 2013, 21:31 »
Yeah but those Rota wheels have a mega low offset don't they?
« Reply #9 on: 15 September 2013, 21:46 »
Yea I didn't like the idea of shaving my brake calipers
