Author Topic: Advanced Tele Prep means no MDI Port  (Read 67631 times)
Offline NickNotts
Re: Advanced Tele Prep means no MDI Port
« Reply #10 on: 15 September 2013, 16:17 »
Are there any instructions on that then? As the track format is itunes...?
Offline matchboy
« Reply #11 on: 15 September 2013, 17:23 »
There's a music thread somewhere - have a look in there, towards the end there's some good info from Craig - sorted me right out!
Audi RS5 2018
Gone: BMW M4 LCI Competition Package
Previous: Mk 3 Audi TTS, Porsche 981 Cayman S, Mk 7 Golf R, Mk 7 GTI, Mk 6 GTI, Mk 5 GTI and so on....
Offline monkeyhanger
« Reply #12 on: 15 September 2013, 17:31 »
Thanks matchboy... the radio didn't like the exFAT format as suggested in that post. Reformated to FAT32 and plays fine, only down point now is I don't have artwork for the media as its in itunes format. Playing from SD card also is a bit bland, and going to have to do my own playlists now too.
You can get all the artwork off the pictures on amazon. It's a bit of a task but it is worth it!
It's not much of a task if you use the program I suggested - it finds the artwork for you and embeds it in 2 steps if you're lucky enough to find artwork less than 400 x 400 on Amazon.
Offline neilgcal
« Reply #13 on: 15 September 2013, 18:53 »
I was horrified to find that when you choose the Advanced Telephone Prep you lose the MDI port in the front storage compartment, meaning I now have a problem with using my ipod in the car. Yes, I can stream bluetooth audio but you can not browse the phone for media etc so have to ensure that you are on the album or playlist when you get in the car.
I stupidly thought that the USB port in the compartment meant that I could plug the ipod in, but alas, no. Yes it charges it, but doesn't recognise the device at all and am unable to play from it.
So now my only option is SD card for media playing in the car?? Have I missed anything or has anyone else found a way around this?
That's a bummer. I have my car on order and have advance telephone prep only as I have to take it with the climate screen!!
When you do connect your iPhone via Bluetooth can you skip songs in the album or play list your in by using the buttons on the media system or the steering wheel or must you do it on the phone itself??
Also does the iPhone 5 work properly with the advance phone prep? I'm sure I had read previous posts that it wasn't fully compatible!!
Offline JellyB
« Reply #14 on: 15 September 2013, 19:50 »
This is a disappointment, as I would have hoped that advanced would mean better than standard.
So all you get is the coupled phone antenna in the place where the USB charging socket is.
If this is a change from previous vehicles I would have a bit of a pop at the dealership.
Offline NickNotts
« Reply #15 on: 15 September 2013, 21:40 »
Ok, to clear this up. The advanced telephone prep gives you an induction plate in the centre arm rest, where you are expected to put your mobile phone in order for it to connect to the external aerial. There is no physical connection for the phone to the aerial, however there is a 5V USB port which is for charging ONLY. Manual states for the optimum connection the phone should be put inside the netted holder in the armrest and that no other metal objects should be put in there. Storage useful for nothing else then!
Secondly, as I have found out, in the centre storage locker under the radio, there is no longer an MDI port, all you get is an AUX jack and another USB port. This is connected to the radio, however looking at the manual is only for connecting up an external hard drive. ie similar to the SD Card slot, you can have your music stored on a USB key or external drive.
Yes, when you are using streamed audio via bluetooth the next/back controls on the steering wheel do work so does the track information, however you can not browse the source for music, all you can do is go back and forth with the tracks. Also, yes, the iphone 5 works absolutely fine with the radio over bluetooth. So making/receiving calls, checking address book and scrolling through missed/dialled calls all works fine.
I did notice that when I was driving with my mobile in the armrest the signal indicator on the radio was significantly better. However the real test will be tomorrow night when I am on the phone to the missus on the way home from work, and to see if I drop calls in all the normal places!! Here's hoping the advanced telephone prep was actually worth it.  :whistle: :whistle: :whistle:
However, as stated before, I am shocked they have pulled the MDI port from the vehicle due to the telephone prep, and I will be making a complaint to both my sales rep and to VW regarding this.
Offline EpicUsername
« Reply #16 on: 15 September 2013, 21:46 »
I know the connector was probably designed with just the phone in mind, but just out of curiosity has anyone tried an Ipod touch or the old Ipod Video with it? I'm assuming the OS is the same or similar. They might try and say well the connector isn't needed as your phone will always be in the arm rest, but if it works with the rest of the I-range then it's a moot point really.
Also I've just had a thought. If you now get an additional USB instead of the Apple connector, couldn't you just drop your music into the phones HDD and hook it up like any MP3 storage? I know it's a small consolation, but it's something?
« Last Edit: 15 September 2013, 21:49 by EpicUsername »
Offline peterdoherty
« Reply #17 on: 15 September 2013, 21:54 »
Same here I'll be complaining if its the same case when mines arrives.
I could move all my music to a 128GB SD card (costly but I've nearly 100GB on the ipod) but don't want to (and why should I have to - it is stated in numerous places that MDI is standard throughout golf range and nowhere that its removed with adv phone prep AFAIK). I use the ipod outside of the car too therefore would need to keep 2 things up to date with my collection if this is the case.
What form of compensations should we be looking for this VWUK error?? Probably the marketing depts fault again!
Has anyone tried to hook their iphone/ipod up using a usb cable into the USB socket where the MDI port should be? (not the one in the armrest phone area) to see if it works?
MKVII GTD DSG Carbon Grey 5DR, Dynaudio, Keyless Entry, Rear View Camera, Colour MFD, Park Assist, Winter Pack, Climate Screen, Advanced Phone Kit, High Beam Assist
Offline NickNotts
« Reply #18 on: 15 September 2013, 21:57 »
Yes I have peterdoherty... and you get nothing. USB, as a source, is greyed out and not selectable. So it completely ignores it, that's with both an iphone 5 using the USB lightning cable and an ipod nano USB 25pin connector. Just not visible. Major pants!!
Offline CraigW
« Reply #19 on: 15 September 2013, 21:59 »
Your probably best contacting your dealer before hand because to ask the question. If Nick doesn't have it then no one who specs the phone prep is going to have it either
