Author Topic: Dead pedal plates?  (Read 7358 times)
Offline Booth11
Re: Dead pedal plates?
« Reply #20 on: 23 September 2013, 19:35 »
Well what I have done is removed the dead pedal, drilled it and bolted the plate on.
If you look at it-shine a torch in the footwell-there's a biggish screw in the centre at the back roughly behind the brake pedal,you need remove with a large straight driver and a smaller allen key type plug affair on side of the dead pedal itself,take these out and it slides up and off.
Drill it and bolt the plate on then just fit it back.
Its dead easy!
Cheers, think I'll do this too.   Suppose self tapping screws would work too.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline pryda
« Reply #21 on: 23 September 2013, 20:25 »
I used self tapping screws. takes a bit of force but they go in eventually.
2009 MK6 GTi, Candy White 3dr, Stage 1 Revo, Milltek cat back, H&R SuperSport, RNS510, OSRAM kit
Unphased - NorthWest German/VAG/Retro Meet
Every 3rd Thursday Of The Month
http://www.un-phased.co.uk/
Offline Gtiless
« Reply #22 on: 23 September 2013, 20:43 »
Yes,self tappers were going to be plan "B" if I had to dismantle half my car to get the dead pedal off,but it really is very easy to remove and refit so I figured drilling and bolting is a better method. It is a German car afterall!  :shocked:
Offline Gene Hunt.
« Reply #23 on: 28 September 2013, 07:40 »
..........best way & if you get one from Gulfstream he supplies the nuts & bolts to match. :smiley:
Candy White ED35.
