Author Topic: What have you done to your MK 7 today ?  (Read 4916995 times)
Offline Watts
« Reply #9270 on: 25 February 2019, 18:23 »
Looking good there Watts, a much better contrast.
I’ve just been sat behind a red FL GTD for half an hour or more in traffic and the new tails don’t look as good as the pre-FL darkened ones.
The car colour makes a difference as to whether the dark tails make much of an improvement or not. On the red it definitely does.
Cheers, yes definitely better. Next job is to swap round the wheels as my tyres are now on 10k, need to clean and seal them at the same time plus give the calipers a bit of tlc too. Then I can enjoy the CS centre caps :smiley:
Previously:
Offline Carbon VW
« Reply #9271 on: 26 February 2019, 09:29 »
Got a shard of wood into sidewall of tyre on commute this morning. Got pressure loss warning. Tyre is toast. Pumped it with compressor I keep in car to get to garage. Bad luck  :cry:
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline gtiaps
« Reply #9272 on: 27 February 2019, 10:11 »
I'm very pleased with the end result, I think the original lights looked a bit fussy. Will keep the old ones though for possible refitting when I sell my car.
[/quote]
Looking well Peter does make a subtle difference  :grin:
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline Watts
« Reply #9273 on: 27 February 2019, 13:06 »
[/quote]
Cheers Neil :smiley:
Previously:
Offline MjrSharpe
« Reply #9274 on: 01 March 2019, 10:27 »
Got a new stainless steel exhaust fitted. Very pleased with how it looks and it sounds better too :)
https://flic.kr/p/2eUkyAf
https://flic.kr/p/2eUkz1o
2016 GTI - Tornado Red, M52 remap, DTUK Pedal box, dv+, racingline turbo elbow, forge turbo muffler delete, racingline springs, racingline stage 2 BBK, novus 0.1 wheels, injen induction kit ,st rear anti roll bar, TT short shift, 034 motorsports dogbone upper / lower inserts, sachs organic clutch, custom stainless steel exhaust, res delete, leyo bezels, oettinger rear spoiler, maxton splitter, golf r rear lights
Offline mkviken
« Reply #9275 on: 03 March 2019, 15:22 »
Took the clutch delay valve out
Definitely feels better with the assist spring removed and this done
Golf GTI 7.5 230 white silver
Offline Watts
« Reply #9276 on: 03 March 2019, 16:52 »
I've removed the assist spring and added the clutch stop but didn't get around to this mod, are you able to say in what way it has improved? Cheers :smiley:
Previously:
Offline mkviken
« Reply #9277 on: 03 March 2019, 18:58 »
It makes the clutch bite point more consistent and reduces the feeling that your slipping the clutch when pulling away
With the delay valve in place the bite point varies depending on how quick the fluid can move back and forth. Going from 1-2nd gear the bite point is noticeably different
It now it feels a lot more normal
Also done the direct throttle setting on VCDS. Not massively noticeable but is slightly better when pulling away.
Offline Watts
« Reply #9278 on: 03 March 2019, 19:12 »
Thanks, I need to get around to that then.
Previously:
Offline mkviken
« Reply #9279 on: 03 March 2019, 19:22 »
It’s not hard to do probably took 20 minutes bleeding the clutch with a vacuum bleeder
