Author Topic: What have you done to your MK 7 today ?  (Read 4916941 times)
Offline clubsport
« Reply #8440 on: 21 May 2018, 16:11 »
On this thread your reply was #8442.
If you go back a little to posts #8435 and 8436, it may become clearer?
Offline mcmaddy
« Reply #8441 on: 21 May 2018, 18:06 »
The seller in the eBay listing says he lists a different pipe for non pp to pp where as the listing I've posted says no difference so what's your point??
Offline hog_hedge
« Reply #8442 on: 21 May 2018, 18:54 »
The eBay listing is saying the GTI Performance is different (Mk7.5). Your link says there is no difference between the GTI with Performance Pack (Mk7) and standard GTI (Mk7). So all 230ps engines are the same, the 245ps GTI Performance is different.
This would actually explain why the 245ps GTI sounds noticeably different than the 230, the exhaust is obviously different in some way.
Offline mcmaddy
« Reply #8443 on: 21 May 2018, 19:02 »
No, the listing states mk 7 and mk7.5 and then says the pp is different.
Offline hog_hedge
« Reply #8444 on: 21 May 2018, 19:15 »
You need to read it again. It says GTI Performance (7.5) is different which is not a GTI with Performance Pack (7). They are two separate models. All 230/220ps engines = same, 245ps = different. It’s not hard to understand.
Offline mcmaddy
« Reply #8445 on: 21 May 2018, 20:52 »
Which part of "Please note , this does not fit GTi Performance model , we have a separate listing for this vehicle" does it state thats just for 7.5?? It's not that hard to read an advert is it!!
Offline JoeGTI
« Reply #8446 on: 21 May 2018, 21:06 »
Well the exhaust tips are definitely fatter (like those on the Clubsport) on the 7.5 GTI.
Offline mcmaddy
« Reply #8447 on: 21 May 2018, 21:17 »
Yeah that's been mentioned before Joe but I'd be amazed if VW are using an entirely different exhaust between a 7 and 7.5 GTi. The engines are exactly the same with I'd presume just a slightly different mapping on a 7.5 pp.
Offline hog_hedge
« Reply #8448 on: 21 May 2018, 21:41 »
“GTI Performance” is a model name for the 7.5
“GTI with Performance Pack” is a name for the 7
This is their other link for the “GTI Performance” https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F323257419126 and it clearly states 7.5.
You’re right, it’s not hard to read :grin:
Offline mcmaddy
« Reply #8449 on: 21 May 2018, 21:53 »
Pahahaha since when was the 7.5 out in 2012 which is what your link states??
