Author Topic: What have you done to your MK 7 today ?  (Read 4916956 times)
Offline mcmaddy
« Reply #8430 on: 20 May 2018, 17:10 »
What's the make of your centre resonator delete jaceyboy? Is it louder than standard?
Offline dereks
« Reply #8431 on: 20 May 2018, 17:25 »
It’s now thrown up a warning light. Book says emissions? But it must be linked google seems to suggest water pump being a weakness on this engine.
My 63 plate has been in the garage for this exact same issue - needs a new thermostat housing to cure.  You're lucky if you've just purchased from a dealer as they'll cover it. Seems to be bit of an issue, had mine done locally for about £500 including the water pump (which was fine but it's part of the same housing so might as well have it replaced at the same time).
Thanks, does seem to be an issue on this engine fair few similar on the web and probably the reason it got traded in!
Offline jaceyboy
« Reply #8432 on: 21 May 2018, 09:07 »
Its this one.....
https://www.ebay.co.uk/itm/VW-Golf-GTi-Mk7-Mk7-5-Centre-resonator-mid-silencer-delete-pipe-deres-pipe/362103443051?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Its very subtle and only sounds louder on acceleration
MK7 GTi
Offline clubsport
« Reply #8433 on: 21 May 2018, 10:22 »
The centre resonator delete looks interesting.
From the ebay listing:
"Please note , this does not fit GTi Performance model , we have a separate listing for this vehicle".
I had no idea the GTi PP had a different exhaust system?
Offline Wide
« Reply #8434 on: 21 May 2018, 10:46 »
Put some red stripe on the diffuser and rear wing....  :whistle:
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline jaceyboy
« Reply #8435 on: 21 May 2018, 11:53 »
Nor me but also the R version is different too :nerd:
MK7 GTi
Offline jaceyboy
« Reply #8436 on: 21 May 2018, 12:03 »
Prets on :cool:
MK7 GTi
Offline mcmaddy
« Reply #8437 on: 21 May 2018, 13:35 »
This is the one I'm looking at progressiveparts.com/vagsport-vw-golf-mk7-gti-clubsport-s-resonator-delete-pipe-kit says no difference between non pp and pp.
Offline clubsport
« Reply #8438 on: 21 May 2018, 14:11 »
As I am sure most of us expected!
Offline mcmaddy
« Reply #8439 on: 21 May 2018, 15:50 »
