Author Topic: What have you done to your MK 7 today ?  (Read 4479852 times)
Offline gtiaps
« Reply #6180 on: 23 February 2017, 22:03 »
Mr GTD, out of interest, where are you going to put the caliper stickers ?
I ask as the standard Calipers don't have the smooth cover plate that the PP GTI has, and instead has a big scallop cut out of the units right back to the brake pad ? Can't see where they would fit ?
[/url
Oh if only I had that pic earlier..
Oh Well, when there here (and the car is :grin:) I will test fit them before committing but I think I can safely say they mostly won't be fitted.
£6.50 down the drain...but at least it's not £650 I suppose. :rolleyes:
If your getting your calliper stickers off Adam you do get 3 different sizes and the decals do fit the non PP callipers I know caus I have them on mine lol   :whistle:
how to take screenshots
If you zoom in on my front wheel you can make the decals out  :whistle: :whistle:
« Last Edit: 23 February 2017, 22:26 by gtiaps »
2010 Candy White Scirocco 2.0 TDI
2016 Carbon Grey Gti 2.0 Fully Loaded
COLLECTED 29/4/2016 and well pleased with the GTI😆😆
Offline Mr GTD
« Reply #6181 on: 23 February 2017, 22:55 »
[/url
Phew!!
Thanks Graham, yeah I'm getting them from Adam and like you said he sends three different sizes.
All is well again :wink:
Offline Sootchucker
« Reply #6182 on: 24 February 2017, 07:37 »
p3asa - this is the harness I purchased : http://www.carsystems.pl/vw-footwell-lighting-rear-plug-play-harness,id647.html
One thing to remember is that I wanted to change from the standard White LED footwell lights to put my own coloured LED bulbs in. I already had a couple of "standard" (aka filament bulb type) footwell lights in the garage from my MK V Golf days (part number 6L0 947 415) so used them with my aftermarket bulbs. If you are happy with the white light, then you can continue to use the VW LED footwell lights which obviously have to be purchased separately.
One thing though, from the descriptions on the car systems web site it said "Only one loom is needed for the fitting of both lights (drivers, passengers site)", so I assumed that meant that there was one harness and that both lights for the rear were joined together. Happily though that wasn't the case and each side of the car had it's own cable.
Running the cables wasn't hard, although I wasn't brave enough to unplug the seat wiring so instead I just removed the seat runner bolts and tilted the seat forwards and backwards as I needed to get the access I wanted without disconnecting anything (obviously with the ignition off). You need to unclip the sill trim (which just simply pulls off - just a few clips), and that then allows you access to the kick well trim on either side of the car. I didn't need to remove these fully just prise out slightly (the drivers side one would necessitate removal of the bonnet release handle anyway, and I didn't want to do that.).
So just unplug the stock connection in the front footwell lights, plug the new harness connector in instead, and then plug the factory footwell connector just removed into the female "piggy back" connector on the new harness. Then run the cable down the sills tie wrapping it to the existing harness, then near the front of the seat run the cable under the carpet to where the factory seat harness pops out from underneath the carpet. With the seat free to move and the sill trim unclipped it's very easy to lift the carpet and push the cable though. Then I just ran the cable though holes on the underside of the seat to where the cutout was for the rear lights. Unlike Kevin's expert approach, I didn't put another connection in the cable for removal of the seat, as the small amount of harness that runs though and under the seat can be very easily pulled out if required. Then just cable tie everything in place and re-assemble.
The first side took me about an hour or so, and the second (once I knew what i was doing) about 45 minutes only. Not as professional install as Kevin's but like I said I didn't want to remove the seat and mess with the factory seat plugs etc. However the cables are still invisible and I still have full movement of the seat front and back.
I hope this helps.
« Last Edit: 24 February 2017, 07:41 by Sootchucker »
Offline gtiaps
« Reply #6183 on: 24 February 2017, 08:35 »
[/url
Phew!!
No problem MrGtd but its Neil not Graham lol  :whistle:
Offline Talk-torque
« Reply #6184 on: 24 February 2017, 08:46 »
PP calliper covers can be bought here.
Hight temperature double sided tape anybody?  :grin:
I thought they were cheap at €22, but that's per side, so €44 a pair.
But the PP and non PP/GTD have different callipers.
On a side note how the hell did you make 'here' into a link? I'm too old :rolleyes:
......but they are bigger, so the covers would fit over - if you aren't too fussy! I wasn't being entirely serious!  :rolleyes:
The embedding of the link is formed by [U RL=link]whatever you want to write[/U RL] (without the spaces!) HTH  :smiley:
Roger.
Offline Mr GTD
« Reply #6185 on: 24 February 2017, 08:53 »
[/url
Phew!!
Neil, please accept my apologies. Getting you mixed up with Gnasher.
D'oh moment  :embarrassed:
« Last Edit: 24 February 2017, 08:56 by Mr GTD »
Offline gtiaps
« Reply #6186 on: 24 February 2017, 09:17 »
[/url
Phew!!
Lol no worries assumed was a case of mistaken identity hahaha  :grin:
Offline Watts
« Reply #6187 on: 24 February 2017, 09:26 »
I hope this helps.
Great explanation, I might consider this mod now. One thing though, on the site selling the cables it mentioned about needing coding afterwards, was that the case?
Previously:
Offline Sootchucker
« Reply #6188 on: 24 February 2017, 10:17 »
No coding at all. Think that might be if you car has no front footwell illumination fitting at all.
Offline Watts
« Reply #6189 on: 24 February 2017, 11:14 »
Brilliant, thanks very much for that :smiley:
Previously:
