Author Topic: What have you done to your MK 7 today ?  (Read 4885161 times)
Offline Sanemancured
« Reply #14080 on: 13 April 2026, 18:42 »
Being new to my car I decided to remove the silica gel pouch from the coolant reservoir and cable tie the bonnet release cable box.
I was too late with the silica gel pouch. I got it out and it seems complete but there’s silica gel stuck in the reservoir so I’ve ordered a replacement. I did remove it and I tried to clean it out.
I’m getting the system flushed when the cambelt is done at the end of this month.
I took the car for a run and got a low tyre pressure warning. The tyres are fine and I reset the sensors.
The vehicle information display between the clocks isn’t showing any data.
Offline SuperScaff
« Reply #14081 on: 24 April 2026, 17:45 »
Took the foam out of the arches and cleaned the crud out
Offline rowlers
  • I'm back - MK7 GTI
« Reply #14082 on: 24 April 2026, 19:02 »
Its absolutely ridiculous how crud is collected isn't it!
Offline Yusee
« Reply #14083 on: 10 May 2026, 09:50 »
After 7 and a half years I have finally had to order a new battery.
Car didn’t start on Friday. I jumped it and gave it a long run, but that hasn’t worked, it was dead again yesterday morning.
Ordered a Bosch EFB from an online company called batteries on the web.
I’m only using the car once a week now, after pretty regular use for the first few years but I’m pleased to have got over 7 years from the original.
Offline Adam T7
« Reply #14084 on: 24 May 2026, 13:37 »
Enjoying the glorious weather. Wash and wax early am. Nearly seven and a half years old, 36k on the clock and still a looker (IMO)
« Last Edit: 24 May 2026, 14:49 by Adam T7 »
« Reply #14085 on: 25 May 2026, 21:39 »
Can’t disagree with that  :cool:
Offline joe6
« Reply #14086 on: 01 June 2026, 17:23 »
Using up a service plan and booked tomorrow at vw dealership. Courtesy  car wash now costs £8.99 for dealer to wreck paintwork, with a full power jet wash!  It all gets worse after an audi dealer near me charged a neighbour for disposal of used service parts!
Offline Finglonga
« Reply #14087 on: 07 June 2026, 23:25 »
My 2014 GTI is in for a new Inlet Manifold as my flaps were sticking,it has had a walnut clean as well while it was off. But now No4 injector needs to be replaced before it goes together.
Also one of the coolant pipes has had a leak and is also being replaced. .I could smell coolant but after 5 water pumps I was used ti it I guess.
Offline willni
« Reply #14088 on: 14 June 2026, 12:34 »
Want and had my passenger side top mount replaced (After putting two new ones in, in October), as the squeaking was driving me crazy.
Turned out both weren't in correctly, easy mistake to make as the mk7 top mounts do need to be orientated correctly. So one replaced and the other rotated and it's all good  :smiley:
Offline joe6
« Reply #14089 on: 15 June 2026, 13:14 »
Useful info for future reference Willni.
Just had brake fluid changed. Surprised that quite a few garages use generic standard dot 4 brake fliud when  most modern cars with abs and esp require dot 4 lv specification. "We use the brake fluid required for your car". Oh no you don't!! Could this be a safety issue for the uninformed?
