Author Topic: What have you done to your MK 7 today ?  (Read 4916958 times)
Offline 182_blue
« Reply #2000 on: 09 April 2015, 17:32 »
Krytox is very good I have about 20 bottles  :grin:,  if you can't get it then gummi pfledge is quite good.
I don't like Gummi Pfledge at all.  It seems ok, that is until it rains and runs all down the paintwork, and is a bugger to get off.
In fact I've got 2 full bottles (bought it on a multibuy once) which I will gladly give away to a good home if anyone wants them.
Are you still using the original can?  Blimey that's been good value :wink:
Stop being so nosey! But I'll tell 'cause I like you! :kiss:
I bought a new jumbo spray can last year! :laugh:
That'll last you another 50 years if you are lucky or it will just outlast you  :kiss:  I jest of course  :smiley:
I will happily take the gummi off you :laugh:
I would also be careful with WD40, i once put some on my plastic/ rubber boot bump stops on my lats R and it attacked the plastic part and the fell to bits !!!
Offline Booth11
« Reply #2001 on: 09 April 2015, 17:53 »
182_blue - If you do want it, PM me your address and I'll pop it in the post  :smiley:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline scotland67
« Reply #2002 on: 09 April 2015, 20:12 »
Today I removed the wheels so that I could give them a good clean
Firstly the nuts were really tight, but thankfully I have a torque wrench.
Secondly these wheels are really heavy to lift off.
I should mention I'm 72 although fairly fit for my advancing years.
Also I found accessing the jack( I do not have a trolley jack) and the separate handle tricky.
Anyway after thoroughly cleaning the wheels I used Auto Finesse mint Rims Wheel Wax and lastly treated the tyres with Meguiars Tyre Gel.
It took me about 4 hours but I am pleased with the result
Offline wigit
« Reply #2003 on: 10 April 2015, 21:55 »
enjoyed a bit of sport with a 7GTI tonight, night blue 3 door with wind deflectors, it was a bit one sided
Offline am1w
« Reply #2004 on: 10 April 2015, 21:59 »
Re-fitted a door seal on the driver's side which was badly fitted. VW quality control is pretty poor IMO.
Checked panel gaps, fit and finish and adjusted the Dynaudio.
« Last Edit: 10 April 2015, 22:01 by am1w »
Offline p3asa
« Reply #2005 on: 10 April 2015, 22:11 »
Asker what was up with your seal and are they easy to re fit?
My drivers door sometimes lets some wind in. A very small amount but annoying quite the same. I just presumed it would need new seals? I take it they can be incorrectly fitted?
Offline am1w
« Reply #2006 on: 10 April 2015, 22:20 »
It was the seal along the rear panel which is alongside the trailing edge of the front door. The bottom bit was sticking out when the door was shut and I had to remove the bottom bit and re-fit it into a plastic holder which is right at the bottom. I think the holder is damaged and needs replacing. Difficult to explain.
I don't think this would cause a major wind issue. I think the way the front doors are hung is the main problem.
Offline p3asa
« Reply #2007 on: 10 April 2015, 22:24 »
Ah right cheers.
Offline monkeyhanger
« Reply #2008 on: 10 April 2015, 22:50 »
They knew it was a lease when they built it!  :whistle: :grin:
« Reply #2009 on: 10 April 2015, 22:52 »
I'm sure that could never happen on a mass produced Audi, built to the same procedures with nigh-on the same parts bin, no way at all.  :whistle:
