Author Topic: What have you done to your MK 7 today ?  (Read 4916922 times)
Offline am1w
« Reply #1990 on: 09 April 2015, 14:08 »
It is a bit annoying but I felt much better as mine was not the only car with this fault. In fact, some were really quite a bit worse.
So you're happier knowing everyone else has a wonky car  :tongue:
Is it more an aesthetic thing?  Or has it any detrimental effect on the door closure, seals etc?
The door closes with a lovely expensive sounding thunk and at motorway speeds there is no wind noise.
It is a very minor misalignment which exhibits itself with the weather strip along the front passenger door being slightly proud of the weather strip of the rear door. This is because the front door needs a slight adjustment inwards on the latch. A 0.5mm movement inwards should do the trick.
Offline Booth11
« Reply #1991 on: 09 April 2015, 14:36 »
Mmm, well I'll be looking out for this on mine then.  Hope you get it sorted to your satisfaction.
I'm always wary of door issues.  Not the same as this but I had an issue on my Mk6 with creaking door seals which became intolerable over time.  Tried lots of things and then discovered the joy of Krytox lubricant oil (from a recommendation on here).  Silence ever since, ahhh  :smiley:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline am1w
« Reply #1992 on: 09 April 2015, 14:39 »
WD40 works a treat for me! Do give it a try.  :smiley:
« Last Edit: 09 April 2015, 14:41 by am1w »
Offline Booth11
« Reply #1993 on: 09 April 2015, 15:15 »
Thanks  :smiley:
Krytox (or Dupont 105) is brilliant stuff.  Originally used on the notoriously leaky roof seals of the EOS.  It's picey for a small amount but a little goes a very long way, I still have enough ledf to do another 2-3 entire cars.  Best of all, it works!
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline p3asa
« Reply #1994 on: 09 April 2015, 15:50 »
WD40 is great for most things but the problem with it is it dries out and the squeak that had been previously cured comes back with a vengeance.
Offline am1w
« Reply #1995 on: 09 April 2015, 15:54 »
Well in my limited experience of 50 years of motoring, it has worked a treat on rubber! Sorry I can't rephrase that a bit better, but you get my gist!  :laugh:
Offline Booth11
« Reply #1996 on: 09 April 2015, 16:23 »
I think Krytox fares much better.  Over a year now and my seals are still creak free  :smiley:
I'm sure you could rephrase it better, if you tried  :wink:
Are you still using the original can?  Blimey that's been good value :wink:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline 182_blue
« Reply #1997 on: 09 April 2015, 16:30 »
Krytox is very good I have about 20 bottles  :grin:,  if you can't get it then gummi pfledge is quite good.
Offline am1w
« Reply #1998 on: 09 April 2015, 16:30 »
Stop being so nosey! But I'll tell 'cause I like you! :kiss:
I bought a new jumbo spray can last year! :laugh:
Offline Booth11
« Reply #1999 on: 09 April 2015, 17:27 »
I don't like Gummi Pfledge at all.  It seems ok, that is until it rains and runs all down the paintwork, and is a bugger to get off.
In fact I've got 2 full bottles (bought it on a multibuy once) which I will gladly give away to a good home if anyone wants them.
That'll last you another 50 years if you are lucky or it will just outlast you  :kiss:  I jest of course  :smiley:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
