Author Topic: What have you done to your MK 7 today ?  (Read 4886481 times)
Offline david25
« Reply #13560 on: 11 August 2024, 18:45 »
Looong overdue new rear discs and pads. Only hiccup was apparently some non-PP GTIs had 300mm rear discs (mine included) - from a relatively thorough Google most places say non PP is 272mm rears which is what I had bought. Maybe it's a mk7.5 change?
Was the inner pad actually touching the disc?
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline LSBristol
« Reply #13561 on: 12 August 2024, 09:11 »
Barely
2017 mk7.5 non-PP, Indium Grey, manual
1991 T25 Camper
1967 Beetle 1500
Offline EB2019
« Reply #13562 on: 26 August 2024, 16:38 »
Removed the arch liners from the front, cleaned dried and sprayed with Bilt Hamber Dynax UC. Nothing worthy to note other than dirt build up where the foam block was located.
Foam blocks removed to prevent rust,  they both had dirt and grit on the ends  (the part that sits against the wing) so will likely cause rust long term.
Offline Mikeyd1
« Reply #13563 on: 26 August 2024, 19:36 »
Looks good mate
2017 gti dsg white silver, 3door, dcc , Brescia alloys, pro Nav dvd ,dynaudio, dcc . Rear tints
Offline Watts
« Reply #13564 on: 28 August 2024, 16:42 »
Gave my exhaust tips a thorough clean. Washed, tar remover then polished with Mothers. Nowt special compared with what most of you on here do but to bear in mind, as far as I'm aware, this was the first time they have ever been cleaned. And they looked like 5 years and near 50k of miles mucky. Now, beautifully shiny. Unfortunately the rest of the car is minging.
Previously:
Offline Mikeyd1
« Reply #13565 on: 29 August 2024, 22:04 »
Looks good mate
do these stop wind noise coming through the headlights???
Offline EB2019
« Reply #13566 on: 30 August 2024, 17:27 »
They sit about half way along the arch, kind of in line with the spring. Once the arch liners are removed it's a big area with nothing in it and a lot of metal that might resonate? I think the foam block might just be a baffle to mitigate some noise in the upper portion of the wing from road/tyres, but not sure.  I couldn't detect a difference after removing them. But I've kept them just in case anyone says they are vital for some reason.
« Last Edit: 30 August 2024, 17:52 by EB2019 »
Offline Mikeyd1
« Reply #13567 on: 30 August 2024, 18:48 »
Thanks for reply . I’m doing my arches at the moment . A big chore but glad I’ve started it. I’m just waiting for the dynax uc to dry
Offline EB2019
« Reply #13568 on: 30 August 2024, 20:04 »
Its a bit of a pain to do but pretty satisfying when complete.
Offline Mikeyd1
« Reply #13569 on: 30 August 2024, 20:23 »
Agreed
