Author Topic: What have you done to your MK 7 today ?  (Read 4837028 times)
Offline willni
« Reply #13060 on: 26 July 2023, 11:09 »
I used the VW coil pack tool and it was very easy, get the plug off the coil pack was the more annoying bit.
Where did you get the tool from, anywhere in particular??
Just off Amazon, for hopefully all the use it will get no point buying a good tool. Always buy cheap tools then if you use it enough to break it look at better quality ones, no point having a snap-on philips screwdriver if you only use torx.
ZKTOOL Ignition Coil Puller Tool, OEM T10530, Ignition Coil Removal Tool, Compatible with Audi A3 2013> Golf Seat Leon Octavia Porsche Macan EA888 EA211 Engine https://amzn.eu/d/30tps4M
Offline madstaff
« Reply #13061 on: 26 July 2023, 13:53 »
Thanks, the genuine T10530 tool is about £250, so looking at alternatives.
They all look the same on ebay and Amazon, just wouldnt mind investing a bit more in a decent one.
Bought some hose clamp pliers when i swapped an engine in a A1 TFSi recently and they were absolute garbage, they were fit for nothing after i'd finished, and not through misuse either.
Offline mcmaddy
« Reply #13062 on: 26 July 2023, 17:36 »
Four new Asymmetric 6s fitted at Costco. Initial impressions on the drive home are they appear to be much quieter than the Bridgestones 👍
Offline willni
« Reply #13063 on: 26 July 2023, 20:08 »
I've been there myself, can't remember what it was mind but I remember throwing it straight in the bin.
There's not a lot of options for the ignition puller, it's not very high tech though so wouldn't worry about a cheap one. I'd offer to lend you mine but I'd say postage both ways would be 2/3's the cost of it.
Recently got a new toolbox so I'm trying to be wise and not immediately go fill it with new tools  :laugh:
Offline madstaff
« Reply #13064 on: 26 July 2023, 23:08 »
Yeh right, buying tools is an addiction don't you know??  :smiley:
Offline KieranMc
« Reply #13065 on: 28 July 2023, 19:22 »
Major service today at Ecotune clean bill of health (as expected), got a few bits to do I knew about already in prep for sale! Got rear discs and pads that are about needing done so will do so just making mind up what to get!
Need a new driver side windscreen washer jet and the fixings for back box heat shield if anyone can provide me with a link or point in right direction for the parts would be appreciated!
Indium grey manual Mk7.5GTI
Carbon mirrors
Osram dynamic mirror indicators
Offline willni
« Reply #13066 on: 28 July 2023, 22:12 »
If you're selling it soon, I'd not worry about getting too in-depth in brake discs new owner won't pay you anymore for it!
For heat shield fixings you mean these wee bad boys? https://www.ebay.co.uk/itm/151220590066
And for an update for everyone regarding my coil pack replacement, my mpg went from 28mpg to 43mpg.
« Last Edit: 28 July 2023, 22:15 by willni »
Offline KieranMc
« Reply #13067 on: 29 July 2023, 19:42 »
Yip, that’s the ones there cheers!
Any idea on windscreen washer jet?
Do you think should leave rear discs as is or put decent pagid or the likes on?
The (CM) prets are coming off and will be for sale separately with standard wheels going back on, bumper needs a paint due to paint peeling off in one section…VW not interested then will give a good detail and advertise!
Carbon mirrors
Offline gixerste
« Reply #13068 on: 01 August 2023, 19:53 »
Fitted a Maxton V2 rear spoiler, just a bit bigger than a TCR spoiler but about £200 cheaper  :smiley:
Indium grey D.S.G. Mk7.5GTI pp
Offline rowlers
  • I'm back - MK7 GTI
« Reply #13069 on: 03 August 2023, 18:47 »
Sealed my rear door speakers.
What the seals looked like:
