Author Topic: What have you done to your MK 7 today ?  (Read 4687479 times)
Offline Rob_benton
« Reply #11600 on: 12 August 2021, 09:12 »
Bought a bottle of genuine VW Haldex Diff Oil ready to service the diff and clean the pump filter in my Clubsport.
Managed to grab a bottle off Ebay for 20 quid, I'm in the trade and TPS wanted £39 +vat.
Anybody done this as I'm reading conflicting guides which some say you have to perform a pump relearn after changing the oil and cleaning the pump filter??
I’d be interested to see what the filter is like some say the diff doesn’t have a filter or not required cleaning unless the diff is used a lot.
2014 gti pp dsg
Offline madstaff
« Reply #11601 on: 12 August 2021, 09:58 »
The pump has a small gauze filter on the end which people say to clean whilst doing a fluid change.
Cant fathom if a pump relearn is strictly necessary though which is why im holding off doing mine yet as no VCDS.  :cry:
Offline Rudedog
« Reply #11602 on: 12 August 2021, 14:51 »
The way I understood it was that it works in the same way as half a FWD Haldex system, this means when (?if) the diff fluid is changed then you should do it in the same way as a Haldex fluid change and renew the filter as it usually comes in the change kit.
« Last Edit: 12 August 2021, 16:14 by Rudedog »
Offline willni
« Reply #11603 on: 12 August 2021, 14:59 »
Booked the car in for some window tinting and I'm very tempted to book a photoshoot for it as well, after having one the other night for another car.
Teasers below not Golf related though.
« Reply #11604 on: 12 August 2021, 16:24 »
Nice! A *proper* M3 (?)  :cool:
Offline clubsport
« Reply #11605 on: 12 August 2021, 17:24 »
Madstaff, this may be helpful?
These chaps are OBDeleven agents and only use it to check the fluid temp before draining, i am not aware of the need to recallibrate?
https://www.youtube.com/watch?v=YW6b5myTgvI&list=LL&index=101
Offline willni
« Reply #11606 on: 12 August 2021, 17:58 »
It is indeed (credit to https://reinisbphotography.blogspot.com/ for taking them.)
Offline clubsport
« Reply #11607 on: 12 August 2021, 18:06 »
Nice E30, it has the appearance of a Sport Evo, is it a real one?
(as in a modified/upgraded E30 M3)
Offline madstaff
« Reply #11608 on: 12 August 2021, 18:37 »
Thanks, seen that.
According to these guys,
https://www.haldexrepairs.co.uk/guide-to-front-e-diff-lock-lsd-on-golf-gti-autobahn-seat-leon-skoda-octavia/
a pump relearn needs to be carried out??
Offline clubsport
« Reply #11609 on: 12 August 2021, 19:06 »
I you don't have access to VagCom, you have no option but to drain, blow out & refill the diff without removing the pump, for now?
When I had the diff serviced on my previous GTi PP, I know the VW main dealer, only drained and refilled.
Thanks, seen that.
Edit to add, looking on OBD eleven under lock elctronics, there appears to be an adaptation for resetting diff and pump motor. I haven;t tried this however to see if it is succesful.
DAP responds to the pump removal and guaze ckeaning at 19 minutes into this video;
https://www.youtube.com/watch?v=DDg548RReYw
« Last Edit: 12 August 2021, 19:26 by clubsport »
