Author Topic: What have you done to your MK 7 today ?  (Read 4916995 times)
Offline marnie
« Reply #1080 on: 22 June 2014, 19:05 »
No squeaks, everything is fine except for PDI corner cutting.
Mk7 GTI 5 Dr
Offline Misterp
« Reply #1081 on: 22 June 2014, 20:40 »
Whilst not as exciting as what some of you have been up to, but I fit my 'luxury' car mata after a much needed clean.
If anyone cares this is what they look like
I think they go well with the GTD colour scheme.
Golf GTD mk7 DSG pearl black - collected 25 September 2013.
Offline GrahamFR
« Reply #1082 on: 22 June 2014, 20:44 »
PDI what?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline mcmaddy
« Reply #1083 on: 22 June 2014, 22:10 »
Had to get my front drivers side gaitor refitted at the dealer as it was loose.
Offline marnie
« Reply #1084 on: 22 June 2014, 22:17 »
PDI = VW "Perfect Delivery Inspection"
Mk7 GTI 5 Dr
Offline p3asa
« Reply #1085 on: 23 June 2014, 12:22 »
Marnie good idea with the hole cut out for the jack to go in.
I used the puck method before but it was sitting on top of what I thought was chunky wood. Anyway the wood cracked and unbeknown to me as I was jacking up the car the cracked wood was wedging up the sill at the same time.
£600 repair for carelessness  :sick:
I promised myself I would get a large headed jack so the puck could sit inside so no need for wood.
Offline Snoopy
  • Geoff.
« Reply #1086 on: 24 June 2014, 05:49 »
If they are anything like the ones fitted to either the  mk4, mk5 or mk6 they always pop off the bottom when the suspension leg is at full travel. When on a wheels free lift or jacked up. Easiest way is to just lower the car slowly then once the leg starts to compress push the gator back over the bottom. It sort of slides over the bottom bit. They always seem to make them just that tiny bit short so when they stretch they pull off the bottom. If not they can pull off the top which is not so easy to refit.
Current Garage:
35+ years of GTI ownership.
Offline mcmaddy
« Reply #1087 on: 24 June 2014, 07:44 »
The gaitors aren't meant to just pop off though. Every time they come loose I'll be back to the dealer. They'll get sick first  :grin:
Offline wigit
« Reply #1088 on: 24 June 2014, 20:57 »
Drove the wife to our dealer so she could order her 7R to replace her Pirelli  :smiley:
Offline CraigW
« Reply #1089 on: 24 June 2014, 22:59 »
At least she's avoiding lease deals  :wink: :grin:
