Author Topic: What have you done to your MK 7 today ?  (Read 4916994 times)
Offline wigit
« Reply #1070 on: 20 June 2014, 14:49 »
Wow wigit, how shiny is that!   What a stunning job and should be well protected too  :cool:
very shiny  :smiley:
looks immense :cool:
it looks fast when standing still now, car has so much presence and since with the remap is an absolute weapon :smiley:
Andy the R looks amazing mate! I've just ordered the ceramic gtechniq kit for Bev's new beetle. Great results, roll on November 2015 so I can get mine ordered!
not cheap but well worth the money given the results  :smiley:
« Reply #1071 on: 20 June 2014, 15:01 »
Wow, finally an R that looks like an R should! (and goes like one should too no doubt!)
Spot on Andy!
Offline Sootchucker
« Reply #1072 on: 21 June 2014, 08:20 »
Auto dimming of the DRLs when indicating to turn like the Audis.
Do you have the coding for that please ?
Offline p3asa
« Reply #1073 on: 22 June 2014, 13:57 »
No bother
https://vcds.greg-roberts.com/view-entries/details/1/9
Offline marnie
« Reply #1074 on: 22 June 2014, 14:40 »
Took off the wheels, cleaned and protected, also calipers. Fitted red alloy valve caps and aligned VW caps. Used homemade jack adapter which worked very well with no danger of bending or slipping. A hockey puck with a slot cut in it screwed to two squares of ply. The lower one with a hole cut in it for the jack pad. Found the front gaiters are hanging loose.
Mk7 GTI 5 Dr
Offline GrahamFR
« Reply #1075 on: 22 June 2014, 15:42 »
And could you reattached the gaiters yourself? Pictures?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline marnie
« Reply #1076 on: 22 June 2014, 17:22 »
The bottom of the gaiter bellows has a square channel that looks like it's for some kind of clip. If the bellows is pulled down it pops sweetly over the flange in the picture but for the life of me I can't see how one would fasten it. I tried to cable tie the bellows below the bright metal bit on the leg in the picture but couldn't  tighten it. It would have been an awful bodge anyway. I'm taking it back to the dealer. I'm wondering what VW's procedure is and whether it says to re-fix it? All sorts of crap will get into the shock absorber if not!
Mk7 GTI 5 Dr
Offline peterdoherty
« Reply #1077 on: 22 June 2014, 17:45 »
Got caught doing 58 in a 40 (100m into a 40 zone from a 60)... 3 points & fine (I know its a fair cop!)
But on the plus side the journey after was the first time I passed 50mpg (GTD)
MKVII GTD DSG Carbon Grey 5DR, Dynaudio, Keyless Entry, Rear View Camera, Colour MFD, Park Assist, Winter Pack, Climate Screen, Advanced Phone Kit, High Beam Assist
Offline marnie
« Reply #1078 on: 22 June 2014, 17:48 »
On looking closer the flange should unclip from the channel in the leg, push up, fasten bellows and push back down into channel. I'm not doing it in case I break it!
Mk7 GTI 5 Dr
Offline GrahamFR
« Reply #1079 on: 22 June 2014, 18:43 »
Thanks for the pics marnie, I'll go check mine, do you have any squeaks from it?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
