Author Topic: Pretty urgent. advice needed  (Read 4096 times)
Offline Rod1-gti
« on: 14 September 2013, 10:27 »
My car sounds like it has a noisy bearing at the rear but there's no play in either of them. The noise gets worse after enthusiastic driving but its fairly quiet again after being left for a time.
Is a grinding noise but it also squeaks when i reverse it. Ive had it jacked up to check play and when i spin the wheel thers a slight grinding but nothing overly unusual.
Any advice?
Offline baxxy
Re: Pretty urgent. advice needed
« Reply #1 on: 14 September 2013, 10:51 »
Sounds like your brake pads to me.... mine sounded like a bus in reverse one of my callipers was stuck one  :smiley:
Offline Rod1-gti
« Reply #2 on: 14 September 2013, 11:03 »
Cheers. i wondered if they may have been running dry or something. Im up grading my brakes soon so i guess ill put up with it til then.
Am i right in thinkin bearings make more of a whirring noise when they're knackard?
Offline baxxy
« Reply #3 on: 14 September 2013, 11:15 »
Yeh they normally get louder the faster you go  :smiley:
Offline Rod1-gti
« Reply #4 on: 14 September 2013, 11:19 »
Mine do but its a grinding/sqeakin noise
Offline baxxy
« Reply #5 on: 14 September 2013, 11:23 »
Sounds like your rear brake pads are down to the metal go and take ur wheels off and inspect your pads mate see what condition your discs are in aswel  :smiley:
Online barrym381
« Reply #6 on: 14 September 2013, 11:25 »
sounds like your wheel bearing  :smiley:
Offline Rod1-gti
« Reply #7 on: 14 September 2013, 12:49 »
After driving home from work Im convinced it the drivers front bearing. it making a metallic ticking noise and speeds up with the car. quieter when turning left louder when turning right.
Offline Rod1-gti
« Reply #8 on: 14 September 2013, 13:29 »
How do i share a video on here?
Offline mcgee9t2
« Reply #9 on: 14 September 2013, 13:38 »
post a link...
