Author Topic: Steering Rack / Suspension Squeak  (Read 153053 times)
Offline andyk11
Re: Steering Rack / Suspension Squeak
« Reply #210 on: 11 December 2013, 22:03 »
Mine's been squeaking and rattling like a good 'un since new.  The symptoms with mine were most apparent at low speed over unsettled or rough roads.
Well, today I finally got around to taking her in to be looked at.
I took the VW tech out for a test drive to demonstrate the noises.  As soon as he heard it he instantly recognized it as the front suspension... apparently they've had a few in recently with the same issue.
An hour later I get a call to say it's all fixed and lo and behold it's quiet as a mouse now  :smiley:
However, with mine the suspension mounts were fine and no transport blocks had been left in. Instead, it was the suspension strut gators / rubbers that needed refitting.
Apparently when the transport blocks are removed sometimes the gators don't get refitted properly.  It's such a common issue that VW have issued TPI 2035921/1 for it.
Tornado Red GTD ordered 25th April, confirmed BW34. Built sometime in BW36, now in the UK and delivered 27/09 :-)
Offline Mr Savage
« Reply #211 on: 11 December 2013, 22:07 »
Yep same issue for me mate. Was also the gators that were out if alignment from the transportation process.
Current - MK7 Golf GTI - Tornado Red, 5 Door, DSG, Performance Pack, Dynamic Chasis Control, Panoramic Sunroof, Discover Navigation, Dynaudio.
On Order - MK7 Golf R - Pearlescent Black, 3 Door, DSG, Vienna Leather, Discover Nav Pro, Rear View Camera, High Beam Assist, Keyless Entry, Dynaudio (Tech Pack)
All gone.
Now;
MK7 Golf R - Lapiz Blue, 5 Door, DSG, Carbon Nappa, Discover Nav Pro.
Offline noobmonkey
« Reply #212 on: 11 December 2013, 22:12 »
hmmmm mines been pretty good, but i do live in a ridiculously bumpy area with many speed bumps....  Every so often i think it might be odd, but then on a normal road etc it is fine.... Is it a really defined squeak/clunk etc?
VW Golf MK7 GTD Manual 5DR Pure White
Offline Mr Savage
« Reply #213 on: 11 December 2013, 23:30 »
It's more of a knocking sound, hard to describe. It used to go nuts over bumpy roads but since I took it in it has improved, although it still isn't perfect in my opinion.
All gone.
Now;
Offline monkeyhanger
« Reply #214 on: 12 December 2013, 08:01 »
I get a few knock/pop sounds when going to the extremes of the steering range in a parking maneuvre - i'm assuming it's the boot gaiter fins becoming unstuck as they are stretched near full lock.
Offline matchboy
« Reply #215 on: 12 December 2013, 11:16 »
Ok, so my car went in yesterday and its back now - exactly the same issue, they had to reposition the suspension gaitors - I now am squeak/rattle/grinding free!!  :smiley:
Audi RS5 2018
Gone: BMW M4 LCI Competition Package
Previous: Mk 3 Audi TTS, Porsche 981 Cayman S, Mk 7 Golf R, Mk 7 GTI, Mk 6 GTI, Mk 5 GTI and so on....
Offline andyk11
« Reply #216 on: 12 December 2013, 12:32 »
It's weird, who'd have thought that a couple of gaitors could cause such a horrible noise... at times it sounded like the suspension was going to detach itself from the car!
I suppose the sound must transmit through the suspension turrets and into the bodywork behind the dash.
Offline 2014GTi
  • Das Auto
« Reply #217 on: 12 December 2013, 12:34 »
So is this the root cause and fix for all these horror stories about the suspension  :undecided:
Quote
I have only covered 239 miles so far and no signs of noises......  :smiley:
2014 Volkswagen Golf GTi
2004 Volkswagen Golf R32
2011 Volkswagen Polo Bluemotion
2001 SEAT Arosa TDi S
1999 John Cooper Mini Works S
2005 Vauxhall Astra SRI CDTi
2002 Audi S3 quattro
1999 Peugeot 206 Grand Tourisme
Offline Mr Savage
« Reply #218 on: 12 December 2013, 13:57 »
Mine still isn't perfect though. Is everyone else's okay? Turn off your head unit, drive down a bumpy road at around 5-10mph, the knocking sound is almost gone & less frequent but I can still hear it. Also when going up a speed bump & down the other side there is a clunk/knocking sound still coming from the driver side wheel. Without having another GTI to test this in can you guys do me a favour & listen to what sounds your car is making over bumpy roads?
Cars back in on Friday for me to talk to the mechanic who worked on it so I should readdress this issue as it's still not quite right.
All gone.
Now;
Offline andyk11
« Reply #219 on: 12 December 2013, 14:24 »
Quote
Unfortunately, not quite.  This is the issue I suffered from and appears to be quite common but thankfully it's a quick fix.
Other people are being affected by the separate issue of noisy suspension caused by faulty mounts which then need replacing.
