Author Topic: Steering Rack / Suspension Squeak  (Read 153051 times)
Offline mk7gti
Re: Steering Rack / Suspension Squeak
« Reply #100 on: 23 September 2013, 21:59 »
Three in both front springs none in the rears...
MK7 GTI - Deep Pearl Black - Standard Spec - Ordered 10/12/2015.
MK7 GTI - White - Standard Spec - Service Pack - Collected 11/09/2013.
Offline harryhackenbacker
« Reply #101 on: 24 September 2013, 07:38 »
Thank You  :smiley:
MK7 R 3 DOOR DSG PEARL BLACK FULL SPEC CARBON
LEATHER
Offline phil_790
« Reply #102 on: 24 September 2013, 17:38 »
Hi guys,
Just got back from the garage, they have replaced the top joints on both sides, they said that one 1 side it was dry which was causing the noise, as a result of a manufacturing defect, they decided to do both sides at the same time just in case. I am not that technical with cars, but it seemed like quite a big thing for them to have to replace after a week!
It didn't make any noises on the short drive back home, but will keep an eye on it. Hopefully it will all be good from now on.
Also I was very surprised after chatting with the salesman, it turns out they sold my scirocco after 2 days on the forecourt, to be honest though when I went to the garage this morning, I did look at the scirocco and think how good it looked!
Cheers,
Phil
Offline mk7gti
« Reply #103 on: 24 September 2013, 20:03 »
Phil did they replace your suspension mounts mine are being replaced on Saturday?
« Last Edit: 24 September 2013, 20:07 by mk7gti »
Offline p3asa
« Reply #104 on: 24 September 2013, 21:10 »
On a side note apparently there is a bulletin out for noisy steering that's linked to wet weather. That one to watch. Currently there are no advised actions or production changes to resolve this problem.
Came across this on an Audi forum, I wonder if its similar?
"After a lot of searching the web, it turns out that when wet, the ripple part of rubber gaiters at the end of the driveshafts, they stick together and come apart, and it's the coming a part that makes the noise that sounds like a grinding.
I proved this by waiting until it's dry outside, finding a car park and while driving putting the steering on full lock both ways (no sound) , then I parked up and poured a bottle of water over the driveshaft gaiters and then put the steering on full lock again (grinding type sound)."
Offline phil_790
« Reply #105 on: 24 September 2013, 21:31 »
All,
I was wrong when I said it was the joints  :embarrassed: it was the suspension mounts that were replaced on both sides.
Cheers,
Phil
Offline mk7gti
« Reply #106 on: 24 September 2013, 21:34 »
Cheers Phil good to know keep me posted on the outcome.
Offline monkeyhanger
« Reply #107 on: 24 September 2013, 23:19 »
I hope my joints were checked and confirmed as fine.
Offline Dully
« Reply #108 on: 25 September 2013, 12:13 »
Just catching up on some threads in detail and this suspension puck issue is a little concerning.
I have just rung directly through to the workshop manager at my dealer to discuss this and he is aware that the cars have the suspension protected for transportation but is now feeling uneasy after I have explained issues highlighted here.
He is going to follow it up, my car had PDI yesterday so it will interesting to see what he comes back with.
Watch this thread  :grin:
Driving - MK7 GTD, 5 Door, CSG, DSG, Santiago's
Offline Blades72
« Reply #109 on: 25 September 2013, 12:27 »
Spoke to my dealer y'day about this and they were aware of the top block being out of view as the dealer himself was driving around for a few days with said block in place. They had to recall about 5 cars to get them removed, still going to double check when I finally collect though. :whistle:
Gone :Mk7 GTI with Performance Pack, Pure White, Dynaudio & Extended Warranty.
Arrived: Mk7.5 PP DSG Tungsten Silver
