Author Topic: Steering Rack / Suspension Squeak  (Read 156757 times)
Offline monkeyhanger
Re: Steering rack squeak
« Reply #10 on: 21 September 2013, 18:21 »
Hi,
I also have a noisy steering rack, but it's more of a creaking noise when at full left lock, car is booked in for Tuesday for them to have a closer look after I popped in the other night. The technician I spoke to said he has seen a similar issue on standard mk7 golfs.
All these issues so early on are a bit worrying...German build quality....
Cheers,
Phil
There have been steering rack issues since at least MK5 with all Golf platform models affected in the MK5/MK6 era - Octavia/A3/Leon/Scirocco. My first MK5 Golf went through 2 steering racks. Neither failed, but were noisy near full lock with a single thump noise heard when first moving if full lock was on.
Offline phil_790
« Reply #11 on: 21 September 2013, 18:27 »
To be honest, as long as the dealer is pretty good at fixing these things them I am not too fussed. Buying a fairly new model there are always going to be some teething problems.
Still loving the golf...always trying to find an excuse to go for a drive!!
Cheers,
Phil
Offline mk7gti
« Reply #12 on: 21 September 2013, 18:28 »
Good to know Phil.
Mine happens when parking the car and completing slow makeovers. If you drive in a straight line at say 2 miles per hour and move the steering wheel left and right a 1/4 of a clock I hear a squeak and grinding noise. I hear nothing at speed.
Re the suspension issue when i corner or move over speed bumps and say 10 mph I hear a creak. To be fair it could all be related to the steering rack. Hopefully its just a new bearing required.
MK7 GTI - Deep Pearl Black - Standard Spec - Ordered 10/12/2015.
MK7 GTI - White - Standard Spec - Service Pack - Collected 11/09/2013.
Offline GTI7me
« Reply #13 on: 21 September 2013, 18:43 »
Guys just been out driving the GTI tonight and have noticed a squeak from my front right wheel when moving over bumps mainly at low speeds. Anyone else noticed anything similar?
I have the same noise... I was actually going to start a thread about it tonight too. I should probably make a trip to the dealer then...
It didn't start right away, only after about 500 miles.
J
2013 GTI (GONE) - 2014 GTI Performance Pack - Manual, Discover Nav, 5 door, Park Assist
Offline mk7gti
« Reply #14 on: 21 September 2013, 18:49 »
Everyone go find speed bumps tonight and see if we all have the same issue  :smiley: Its nice to know I'm not the only one. GTI7me do you have the same noise as me when doing parking manoeuvres i.e. slow turns of the wheel?
« Last Edit: 21 September 2013, 19:02 by mk7gti »
Offline GTI7me
« Reply #15 on: 21 September 2013, 19:10 »
Yes exactly the same, mk7gti. I read somewhere that it's worse when it all gets really wet in heavy rain (which we have had a lot of).
I will take it in to the dealer when i get a chance and see what they say. When are you going in?
J
Offline mk7gti
Re: Steering Rack / Suspension Squeak
« Reply #16 on: 22 September 2013, 10:30 »
16th of October is the earliest they have a lone car. It's so nice to know we have the same issue and I'm not the only one. Sorry for bringing it to your attention if you hadn't already noticed both issues. It maybe a simple joint needs a some lube.
PS did you spec DCC? I didn't I wonder if thats the root cause..
Offline mk7gti
« Reply #17 on: 22 September 2013, 10:34 »
Offline SA-GTI
« Reply #18 on: 22 September 2013, 11:52 »
Also have a squeaky/creaky suspension. Mine has been diagnosed being the front shock mounts which is a known issue.
Offline mk7gti
« Reply #19 on: 22 September 2013, 12:19 »
Thanks SA-GTI great info. I take it the fix worked?
