Author Topic: gt28rs turbo  (Read 4889 times)
Offline dom
  • Back in a Mk4
Re: gt28rs turbo
« Reply #10 on: 14 September 2013, 12:13 »
Depending on your current spec, I'd say set aside £1500 for it.
f**k i was nearly that for a turbo,manni an new fuel pump  :cry: then the cost to have them fitted
That was assuming he is being given the turbo for nothing :grin:
Online barrym381
Re: gt28rs turbo
« Reply #11 on: 14 September 2013, 12:20 »
the turbo he is being given needs a rebuild  :cry:
Offline sharki786
  • GOT BOOST??
Re: gt28rs turbo
« Reply #12 on: 14 September 2013, 14:03 »
Ye lads its free. But does need rebuilding as the bearings are fooked. He had something missing on the oil feed pipe so oil was just pushing past the bearings and they wore out.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
Re: gt28rs turbo
« Reply #13 on: 14 September 2013, 16:33 »
Beach buggy wants about 400 for rebuild :lipsrsealed:
Manifold - 500
Will a lcr fuel pump do?
Which injectors?
Me and my unc will be putting it together hopefully.
P.s beach buggy said about top mouting the turbo??
*****MK4 GTI T*****
Offline golfyste
  • Project track car
Re: gt28rs turbo
« Reply #14 on: 15 September 2013, 20:26 »
Gonna need:
Downpipe
Oil feed/return
Coolant feed/return
Air Intake pipe
Rods
New gaskets and bearings for engine while fitting rods which also means you might as well replace the rings
Bigger injectors (probably 550's from badger 5)
S3 maf or maybe bigger
Cupra r pump maaaaay be ok but would be safe to have a uprated pump
Custom fmic pipes I account for turbo bein in a different place
Etc
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
Re: gt28rs turbo
« Reply #15 on: 15 September 2013, 22:25 »
Not to mention a remap to get the most out of it. Also I would say Con Rods would need to be replaced too?
I thought Volkswagens were supposed to be reliable?
Offline golfyste
  • Project track car
Re: gt28rs turbo
« Reply #16 on: 16 September 2013, 01:40 »
Yeah I said rods but your right will also need a map!
And also a clutch which is about £800
Your lookin at about 360 bhp and a good £2500+ in parts
Offline sharki786
  • GOT BOOST??
Re: gt28rs turbo
« Reply #17 on: 16 September 2013, 06:30 »
 :shocked: :shocked:
Also which clutch is that for 800?
And a manifold
« Last Edit: 16 September 2013, 06:35 by sharki786 »
*****MK4 GTI T*****
Offline golfyste
  • Project track car
Re: gt28rs turbo
« Reply #18 on: 16 September 2013, 06:31 »
.....turns out more expensive then you first think  :laugh:
Offline sharki786
  • GOT BOOST??
Re: gt28rs turbo
« Reply #19 on: 16 September 2013, 06:35 »
f**k trust me
Which clutch do i need thats 800?
*****MK4 GTI T*****
