Author Topic: Minor niggles.  (Read 23025 times)
Offline GolfTi
  • ..gotta feel for my automobile..
Re: Minor niggles.
« Reply #20 on: 13 September 2013, 20:40 »
The wiper blades seem to have become quite an issue. According to this:
http://www.golfmk7.com/forums/showthread.php?t=469&page=4
Bosch are releasing a new set of blades for the Mk7. Possibly a free dealer replacement?
I had mine replaced at the 1k check up. The new one did exactly the same thing.
It seems to be sorted now though, I think it just needs to wear down a bit.
Not great on a new car. I still might call into my dealer for a Bosch wiper (or two).
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
Offline monkeyhanger
Re: Minor niggles.
« Reply #21 on: 13 September 2013, 21:40 »
My wipers have improved a lot with more rain today, although you can't really tell when it is sorted until you get smears with very light drizzle.
Smeary VW wiper seems to clear a lot of rain well, but a little not much. I generally find auto sensitivity works best with the stalk toggle 1 click away from max. It would be handy if the springy flick was between auto and off - to make it handy to do a top up wipe when auto just doesn't cut it (like for light drizzle or when a big drip rolls off the roof, going nowhere near the sensor)without knocking the auto off.
My Xenons have been on in everything but blazing sunshine, even with the auto lights set to "late".
My mpg is sh!te right now. Started on an indicated 50mpg for my first few trips.DPF attempted a regen between 65 and 85miles, achieving 45mpg indicated whilst doing it. My 170TDI Scirocco would manage 50mpg right now and the GTD is supposed to be 20% more frugal. Haven't experienced appreciable gains with the miles going on with past VWs, but it seems to be the case with the MK7 - my dad's GTD has gained about 10% in 4k miles going on it. Will fill with V-power as soon as I use up all my delivery diesel, it gives about 5% better fuel economy and far fewer DPF regens (which kill mpg) on my Scirocco, presumably due to it's cleaner burn and higher purity.
I have a squeaky passenger door seal.
Spent tonight stripping my Autoglym (because it won't last 5 mins apparently) and applying G-Techniq C2V3 instead. I now have the Teflon feel on my car's bodywork. Using the treated hydrophobic application pad worked wonders for minimising use of product. Pooling of water was highlighted during the process of stripping and cleaning, especially on the top of the rear bumper, under the tailgate lip.
I wanted to shift my car a few feet and the handbrake would not disengage - coudn't figure out why until I put my seatbelt on. It would not disengage without you being belted up. Highly annoying - I presume going backwards instead of forwards would disengage, but didn't tryit.
Offline JoeGTI
Re: Minor niggles.
« Reply #22 on: 13 September 2013, 21:45 »
If you put your foot on the brake pedal you can disengage the handbrake manually.
Offline matchboy
Re: Minor niggles.
« Reply #23 on: 13 September 2013, 23:05 »
MH I tried to reverse this mk 7 without the seatbelt on with the hold assist on - it wouldn't reverse until I put the seatbelt on - highly irritating as was only going a few feet!
Audi RS5 2018
Gone: BMW M4 LCI Competition Package
Previous: Mk 3 Audi TTS, Porsche 981 Cayman S, Mk 7 Golf R, Mk 7 GTI, Mk 6 GTI, Mk 5 GTI and so on....
Offline mcmaddy
Re: Minor niggles.
« Reply #24 on: 13 September 2013, 23:30 »
you don't need your belt on to move. keep your foot on the brake and press the ebrake switch. brake will disengage and allow you to move off.
Offline JJH
Re: Minor niggles.
« Reply #25 on: 13 September 2013, 23:33 »
Picked up today, felt like Christmas.
Dealership did well, spent 20 mins going through the vast array of settings etc.
Features that impress (however small) include:
The clock
The standard stereo's quality
3rd gear shove
Ride
Mirror closure at lock
Interior lighting (adjusted to the max, clock on dullest)
Profiled indicator arms
Cornering lights
Short gear throw
Lap timer (unused)
World car of the year sticker in the rear window
Improved heating / AC
Slight niggles:
New key orientation
Hill hold doesn't remain on
iPhone cable is too long and can prevent opening of compartment, beware (now knotted to shorten)
Roof and window closure at lock doesn't work ( being looked into)
Headlamp washers operate when unnecessary.
However, overall very impressed. Big improvement over mk6.
GTD White 5dr, ACC, Sunroof, winter pack, in transit.......
Offline ChrisJL
Re: Minor niggles.
« Reply #26 on: 14 September 2013, 00:03 »
Didn't realise you could change the auto lights to this "late" setting, or that there was any kind of setting to adjust the time / sensitivity of that! Read good chunks of the manual but missed that.
Need have a good sit in it tomorrow and go through every single menu I can find I think... Probably need a useful tips / settings thread :P
Collected 10/09/2013: Mk 7 Golf GTI. 3 Door Manual. Tornado Red. Performance Pack. Adaptive Chassis. Winter Pack. Life Shine Protection.
Offline Bill_the_Bear
  • Yes! Wait a minute... No!
Re: Minor niggles.
« Reply #27 on: 14 September 2013, 01:00 »
2) Not a niggle but a potential problem - the doors do hold at a certain opening point but its not big enough to get out.    Therefore if you open it a bit further and let go it just swings open. You have to keep reminding passengers (i.e. the Mrs) not to let go of the door. I can see that dreaded moment when it swings open and smacks a wall  :sad: :sad:
Oh I hate this one.  There are certain things I know my wife's brain just isn't wired to consider as important and I'm always saying "remember to do X".  She gets pissed and gives me the glare so I say "ok I won't remind you but if X happens then I'll be real upset."  What happens 5 minutes later? :angry:
Of course its then explained to me how really its my fault, rubbing salt into the wound. :sad:
Re: Minor niggles.
« Reply #28 on: 14 September 2013, 10:58 »
Seems to do nowt TBH. In a pretty bright day but not blazing sunshine my Xenons were still on.
Re: Minor niggles.
« Reply #29 on: 14 September 2013, 22:13 »
Few more minor niggles. I thought the menus for the MFD could've been a little better thought out in order of appearance. I expected the trip info (mpg, temps etc) to be right next to the audio with nothing in between, seeing as I expect most people to be flitting between these 2 modes the most when on the move (as I am). The safety features are wedged in between (safety first I suppose).
My handbrake/autohold has driven me mad today. release of the car has been intuitive and as expected from Tues to yesterday, but at times today it seems to have clamped on an not let go in certain situations, like reversing into a space and then shuffling forward to straighten up has required a hard press on the brake pedal at every direction change - feels very un-natural.
