Author Topic: 1.8T reving when clutch down?  (Read 6728 times)
Offline harlemex
Re: 1.8T reving when clutch down?
« Reply #20 on: 16 September 2013, 20:58 »
mine is exactly the same.  :sad:
Offline Carl18T
« Reply #21 on: 18 September 2013, 18:19 »
Hi Harlemex I'm still trying to find out what's the cause of it? Have you got maps on your car? I'm trying to see if an APR map issue. Mine is getting on my tits now.
Offline harlemex
« Reply #22 on: 20 September 2013, 12:04 »
mine has a revo stage 1, however it was doing it before the map. ok to drive slow, but as soon as you put your foot down abit, the problem happens. im gonna take it to revo next week, and ask them. will let you know.  :smiley:
Offline Carl18T
« Reply #23 on: 20 September 2013, 16:05 »
Hi that would be worth trying see what they say.  Mine is really doing my head in now.  Let me know when you've been
cheers
Offline Carl18T
« Reply #24 on: 25 September 2013, 20:49 »
Bump....
jamie16v
« Reply #25 on: 27 September 2013, 21:17 »
Clutch pedal switch maybe?
Oops just re read, already replaced it  :tongue: damn iphone
« Last Edit: 27 September 2013, 21:18 by jamie16v »
Offline Carl18T
« Reply #26 on: 02 October 2013, 20:37 »
I've decided to stick a new clutch in to see if that sorts it. I have a feeling it is the clutch starting to slip but only when under high revs,
Offline harlemex
« Reply #27 on: 02 October 2013, 21:37 »
went to revo today told him issue he just scratched his head. my car has started holding back on boost and kind of juddering. He said buy a new air mass meter and get new plugs. The ones I have are only a few months old (denso europarts cheapies) the engine is fine at low revs, he said my plugs read upto .8 instead of a maximum of .5 if anyone knows what that means? He also said the maf was reading 40grams, and that was low???
Offline Rhyso
« Reply #28 on: 02 October 2013, 22:00 »
Just 40gms?? Oopps!!!
To run 200bhp it should be reading approx 160gms when producing its peak power
Unplug it and see if it runs better  :wink:  if it does its goosed
Offline harlemex
« Reply #29 on: 02 October 2013, 22:11 »
cheers Rhyso. seems mine is way off then  :cry: I just went for a spin with it unplugged and it felt the same. However when I plugged it back in and tried again it was as if I had a new car  :laugh: For now (at least) it seems to be running ace. How weird??
