Author Topic: 1.8T reving when clutch down?  (Read 6714 times)
Offline Carl18T
Re: 1.8T reving when clutch down?
« Reply #10 on: 14 September 2013, 13:22 »
Hi again, sorry not been on for a few days.  Its not the clutch as its fine when accelerating pulls really well and no slipping at all. But if i rev it to much like say close to the red when i dip the clutch to change up a gear the revs just carry on going. Dont worry either ive lifted off the pedal.
Thanks again
Carl
Offline Carl18T
« Reply #11 on: 14 September 2013, 14:02 »
Hi again, Im back from test run after cleaning TB which was not bad anyway, just a little bit of carbon around the butterfly, bad news is its still doing it. first and second if i give it enough revs before shifting up a gear? Went into the red before revs came back down the other issue with this is you cannot get it into the next gear until the revs have dropped enough.
Any further advise would help a lot!
thanks
Carl
Offline Nino
« Reply #12 on: 14 September 2013, 18:12 »
Your TB cable driven or electronic? If its cable driven the cable could be getting stuck?
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Carl18T
« Reply #13 on: 14 September 2013, 21:57 »
Electronic so no cable? I really don't know what else to try.
Offline gazareth
« Reply #14 on: 14 September 2013, 23:27 »
hey that's what I said you info thief.
Offline gazareth
« Reply #15 on: 14 September 2013, 23:44 »
maybe the cyborgs are finally taking over and their using you as a test piece.
Offline james18t
« Reply #16 on: 15 September 2013, 12:32 »
Could this be map related? I know some maps come with a brake and boost function.. I think how it works is similar to left foot braking, but the computer keeps the accelerator planted while you brake, so you still have boost ready when accelerating out of a corner. I don't really know the ins and outs but could be something to look into.
Offline Nino
« Reply #17 on: 15 September 2013, 14:38 »
Huh?  :huh:
Offline gazareth
« Reply #18 on: 15 September 2013, 18:20 »
Huh?  :huh:
ah its looks like my post didn't make it through for some reason :angry:
Offline Carl18T
« Reply #19 on: 15 September 2013, 20:09 »
Thanks for all the help and thoughts. I've been scratching all weekend and still can't think of what it could be. I've had it plugged in as well but that didn't show anything apart from the stat so replaced that but knew that needed doing as it took ages to warm up. Thinking of taking it to my local VW Audi specialist psi tuning this week to see if they know anything.
