Author Topic: Reverse lights gone. how to replace switch & part no. required  (Read 1211 times)
Offline mcgee9t2
anyone got a part no. for the switch on top of the gear box, think mine broke...
a few weeks ago I noticed my reverse light going out when I raised clutch... now it doesent work at all. I think its the switch on top of the gear box? thoughts?
anyone got a part no for it? (ARZ Engine code if that makes a difference)
to replace is it just a case of disconnect battery, unclip the harness to it, un-screw it then the reverse for installing the new one?
cheers
Offline beppe2672
Re: Reverse lights gone. how to replace switch & part no. required
« Reply #1 on: 13 September 2013, 11:02 »
The wires have probably broke at the switch, I just resoldered mine and heat shrunk the sh!t out of it to stop it happening again.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline mcgee9t2
« Reply #2 on: 13 September 2013, 11:20 »
Wiring looked fine when i checked last night, but will double check in the light
Offline beppe2672
« Reply #3 on: 13 September 2013, 11:47 »
unplug the switch and short the 2 pins on the connector, if the brake lights come on its your switch, if they dont its more than likely the wiring
