Author Topic: Mk3 cabrio not starting.. Help  (Read 1879 times)
Offline Jeffvwgolf
« on: 11 September 2013, 18:22 »
My head is wreaked with this, 96 or 98 cabrio 1.8 8v, cranking over but not firing, I checked for a spark but it sparks 1 time when cranking but then nothing, and there is fuel getting threw, the problem started 1 day after it was sitting running outside when my friend ran into the house, the car engine then starting idling funny with high revs and then it cut out and hasent started since.. Any1 had this before please need help to get my friends car sorted...
Jeff
Offline Len
Re: Mk3 cabrio not starting.. Help
« Reply #1 on: 12 September 2013, 12:40 »
Have a Search in the Mk3 Section mate loads of different reasons for this problem.
www.sas.org.uk
www.the-ace.org.uk
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 12 September 2013, 12:43 »
Sounds like an immobiliser fault to me.
Unless you've mistaken a skip for a Golf3 cabrio?  Not difficult.
Offline Len
« Reply #3 on: 12 September 2013, 12:49 »
Immobiliser stops the fuel so cant be that!
Sounds like a vacuum hose to me.
www.sas.org.uk
www.the-ace.org.uk
Offline Seanl
« Reply #4 on: 12 September 2013, 17:13 »
The odd spark then nothing, and no one has mentioned coilpack............
Immobiliser would cut it off after a couple of seconds running so it would still start unless its aftermarket.
Offline Jeffvwgolf
« Reply #5 on: 17 September 2013, 01:55 »
Thanks lads, gonna try coil pack first, apparently there a commen fault on them, if I don't get anywhere with this il let yas know, cheers
