Golf mk3
hardmonkeys
warning light
Topic: warning light (Read 1590 times)
nhop10
Mk3 GTi
warning light
10 September 2013, 23:30 »
started up the car the other day and the furthest to the left warning light started flashing on the dash. looks like some temperature warning.?? not sure exactly what for though. it stays on flashing until i switch the engine off then start her up again (when warm it will go out)
i looked in the haynes manual but couldnt see any info in there anyone know what it is trying to tell me
Mk1 Golf 1.1, 6n Polo 16v, and now an 8v mk3 GTi
FlashRedThree
GTI forum regular
MK III Flash Red 1.4 SE + MK V DBP 2.0T GTI
Re: warning light
11 September 2013, 00:03 »
Coolant level / temperature warning light.
Check coolant level in expansion tank when engine is cold and on a flat surface.
If that's fine, it'll most likely be time for a new temp sensor.
Ye Olde 3
GTI 4
GTI 5
Luke1981
Re: warning light
11 September 2013, 19:00 »
Definitely sounds like the temp sender. It's an easy and cheap job to fix.
MK IV GT TDI 150 PD / MKII CADDY SDI
Golf mk3
hardmonkeys
warning light
