Golf mk2
Leak
Topic: Leak (Read 2103 times)
Mcwill
Here all the time
Leak
10 September 2013, 15:47 »
Got a water leak(rain) on drivers side, looks like its dripping down from where all the wires are on the dash
. Any ideas.
Thanks
Sgt_Lemon
8v owners club
Re: Leak
10 September 2013, 16:05 »
Can you be more specific about where the leak is. Where it originating from and where the water ends up. Try and trace the water to a source.
Mcwill
Here all the time
Re: Leak
10 September 2013, 17:48 »
It ends up leaving a puddle in the drivers footwell. It's hard to see where it's coming from looks like it could be coming from the bulk head but had a good look and can't see any bungs or out missing. Got me stumped.
weazgti
Re: Leak
10 September 2013, 18:39 »
Through clutch cable grommet or under the ecu or bonnet release cable bung
Mcwill
Here all the time
Re: Leak
10 September 2013, 19:02 »
Had a look at the bonnet release cable bung and that looks fine. Haven't checked clutch cable grommet or under ecu but will be the next things to check.
Thanks
dragonfly
Re: Leak
10 September 2013, 19:31 »
Is the door card wet? If so water could be coming through the plastic membrane.
Mcwill
Here all the time
Re: Leak
Reply #6 on:
10 September 2013, 19:48 »
Door card is dry.
gazareth
Re: Leak
Reply #7 on:
10 September 2013, 21:54 »
take out your drivers seat and remove the panel below the steering wheel. then lie inside with a torch and get someone with a hose on outside.
jezza16v
Re: Leak
Reply #8 on:
11 September 2013, 12:35 »
Could be the windscreen seal, its leaking both sides on ours, a new seal is on the (very long) job list.
Golf mk2
Leak
