Author Topic: Any one running  (Read 1825 times)
Offline turbokid23
Any one running
« on: 09 September 2013, 17:59 »
A k04-001 if so did u have to change the manifold fown pipe etc? As my turbo broke and had a look at a hybrid and I haven't got £700 for a turbo don't mind paying around £300 for 1
Offline mcgee9t2
Re: Any one running
« Reply #1 on: 09 September 2013, 18:03 »
K04001 is a streight Bolt on iirc. However only see around 10bhp more than k03s.
Also for 300 quid I wouldn't be expecting much.
If it was me I'd be looking to spend minimum 500.
Offline beppe2672
Re: Any one running
« Reply #2 on: 09 September 2013, 18:10 »
how broke is your turbo?
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline turbokid23
Re: Any one running
« Reply #3 on: 09 September 2013, 18:36 »
My car is like its in a episode of stars in you eyes its thay bad got to wait for littco, beach buggy turbo to get back to me
Offline turbokid23
Re: Any one running
« Reply #4 on: 09 September 2013, 18:37 »
It's a k03s that's broke  :cry:
Offline dom
  • Back in a Mk4
Re: Any one running
« Reply #5 on: 09 September 2013, 18:41 »
I'd be sending the K03s to littco, it might cost a little bit more now but it will be worth it.
Offline turbokid23
Re: Any one running
« Reply #6 on: 09 September 2013, 18:43 »
I no he does the k300 turbo good for 300bhp but I'm not chasing big power as getting a Subaru for that, every think seems to happen all at once aswell as people say joys of owning a golf
Offline Scott D
Re: Any one running
« Reply #7 on: 09 September 2013, 19:34 »
direct swap for a k03s, are a waste of money for 10-20hp gain
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline km
Re: Any one running
« Reply #8 on: 09 September 2013, 20:09 »
Quote from: RTech
K03s t0 K04-001 imo is well worth it!!  I still get a huge grin on my face every time I drive my car.
If its willy waving peak pub talk power your after then the k0-001 aint the turbo for you.
If your looking for a usable 1.8T that is very quick, no lag and power on tap across the whole rpm range then the k0-001 is a must have mod.
I think the k04-001 could close on 260bhp "MAX" out, but it wont last long imo,  I know they have enough spool spike to hit over 305lbft hitting 28psi but again not good or safe for the turbo. ( it tested the peak torque on my turbo..lol)
My current map, which peaks 21psi and holds 19psi and sees 14/15psi near the red line is making 245bhp/260lbft.  It dont sound a lot, but when you see the graph and the peak 260lbft holds and flat lines from 3450rpm to 5400rpm, so 260lbft for close on 2000rpm.  Its this broad torque band which makes my car very quick.  A few map revisions back we took the car to santa pod and ran a 13.8s @ 102mph and gave a stage2  280bhp/300lbft LCR a good woop arse kicking.
my only issue if my fuel tails off at 7300rpm, I fitted S3 injectors and mapped them in, to end up with the exact same fuel issue, I think my 150k fuel pump is on its last legs.
can't be that bad.
Offline darren1.8t
  • I HATE FRENCH CARS
Re: Any one running
« Reply #9 on: 09 September 2013, 20:19 »
beech buggy charges 375 mate  :cool:
