Author Topic: tracking after lowering  (Read 1983 times)
Offline gaza2001
« on: 07 September 2013, 08:13 »
hi guys, ive lowered my 8v anni by about 50mm, took it to a garage yesterday to get the front wheel alignment sorted. they got the camber put right but cant get the tracking right as they've run out of adjustment and its towing in about 10mm? any ideas!!
Offline spudboy6
  • Just like a golf ......
Re: tracking after lowering
« Reply #1 on: 07 September 2013, 11:23 »
Its not possible to run out of adjustment ,
I'm down 60 and people are down way more ,
I would hazard a guess that the rack isn't centred for example you may have more turns one way than the other with the steering wheel ?
Offline gaza2001
« Reply #2 on: 07 September 2013, 14:35 »
that's what I thought, I'm taking it back in the week so they can have another look a it? spoke to them this morning and he said it was equal both sides. also found on this forum earlier that I think its the left side track rod should be 406mm and then altered on right hand side?
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 07 September 2013, 16:15 »
^^^ this is correct!
Offline gazareth
« Reply #4 on: 07 September 2013, 18:29 »
I find it hard to believe they ran out off adjustment. but if so then there is adjustment in the lower balljoint to wishbone bolts if need be.
Offline gaza2001
« Reply #5 on: 08 September 2013, 12:58 »
thanks for replies guys, hopefully will get it sorted!!
