Author Topic: Mk2 20vt speedo  (Read 1604 times)
Offline scottishpedro
Mk2 20vt speedo
« on: 04 September 2013, 21:48 »
Hi all
My mk2 developed a rattle in the dash on my big road trip. I needed to replace a dash bulb so took the dash apart and found the rattle. It's coming from the white connector which connects the speedo cable to the speedo. The pin inside the white connector is rattling and causing the noise. I have also noticed the speedo needle not rising smoothly.
Could it just be a new connector required? Can these be bought separately or should I get the whole cable like this?
http://www.ebay.co.uk/itm/SPEEDOMETER-C ... 460bc257da
Finally if I get the cable is it easy to fit at the engine end?
Thanks in advance
Pete
Offline gazareth
Re: Mk2 20vt speedo
« Reply #1 on: 06 September 2013, 00:43 »
is your mileage counter working? when mine stopped turning I was getting a ellish ticking from behind clock but when I fixed speedo head the noise stopped.
