Author Topic: Will a 1.4 16v gearbox work with my 2.0 16v gti engine  (Read 2534 times)
Offline edcasesmk3gti
  • Big GTI Project
« on: 02 September 2013, 21:16 »
Hi all
Will a 1.4 16v gearbox work with my 2.0 gti? I have the drive shafts from the 1.4 and think all i need is the 1.4 clutch and cable is that right? any help would be great.
Cheers Eddie
BOOM
Offline danny_p
Re: Will a 1.4 16v gearbox work with my 2.0 16v gti engine
« Reply #1 on: 02 September 2013, 23:01 »
very very much dought it
all the VW's have gone bar 1.
Offline Ben@VWH
« Reply #2 on: 03 September 2013, 09:18 »
No, unfortunately not. You can use your original 2.0 gti box though (with a decent clutch of course).
  • Big GTI Project
« Reply #3 on: 03 September 2013, 18:40 »
Are you sure the gearboxes are exactly the same bar the spines from the box being smaller than the gti box?
 :undecided:
BOOM
Offline notenoughtime
« Reply #4 on: 03 September 2013, 20:07 »
Box will probably bolt onto engine but as you state it will have smaller shafts which you could possibly break with the increased torque that will be put through them by the 2.0 engine
Offline gazareth
« Reply #5 on: 03 September 2013, 22:13 »
if its the box with the circular green cap on the end then it will fit. you just have to change clutch for a mk2 8v gti set up and you can swap the inner drive shaft flanges over. not sure on ratios though. or teeth on speedo cable gear.
  • Big GTI Project
« Reply #6 on: 03 September 2013, 22:31 »
Cheers Guys
All sorted now, scrapped that idea sourced a GTI box will keep you all posted with the project  :laugh:
BOOM
