Author Topic: Rear caliper issue  (Read 917 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Rear caliper issue
« on: 01 September 2013, 21:04 »
I recently purchased a pair of used mk4 rear calipers to fit on my mk3,  before installing them I thought I'd give them a good clean up,  paint and general check over.
Both pistons wound back easily with the proper tool and both handbrake levers move freely,  the issue I have is that one piston drives outwards with the operation of the lever and one does not.
I was able to withdraw the offending piston using the tool in the opposite direction easy enough and the seals and piston are in excellent condition so I'm kinda stumped as to why it only moves outwards about 3/4mm with the lever before  returning its last position whereas the other piston will keep coming outwards?
« Last Edit: 01 September 2013, 21:08 by thai-wronghorse »
Re: Rear caliper issue
« Reply #1 on: 02 September 2013, 09:26 »
Any ideas guys as the only info I can find is regarding seized pistons and handbrake mechanisms?
