Author Topic: My agu seems to be under powered:-(  (Read 2088 times)
Offline M.sheldon23
« on: 01 September 2013, 15:00 »
Heyup my car seems under powered n slow to 60.
Also seems when i get upto the ton,she has nothing left. This cant be right!! Any ideas? Would be appreciated.
Offline barrym381
Re: My agu seems to be under powered:-(
« Reply #1 on: 01 September 2013, 15:08 »
is it a standard car an has it just started feeling under powered  :smiley:
Offline Nino
« Reply #2 on: 01 September 2013, 15:19 »
sounds like like limp mode?  :undecided:
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline M.sheldon23
« Reply #3 on: 01 September 2013, 15:20 »
Yeah its totally standed, and to be honest not had it long. Its been like it since i got it dint really notice til last couple days when av been out for a good drive and other motors that shunt be as quick seem quicker. And the top speeds not right.
Offline Nino
« Reply #4 on: 01 September 2013, 15:21 »
you need to get that plugged in mate
Offline M.sheldon23
« Reply #5 on: 01 September 2013, 15:22 »
11.5 ish to 60!!
105 tops.
Would that be possible in limp mode?
Offline Nino
« Reply #6 on: 01 September 2013, 15:34 »
cetainly sounds like it
Offline mike1990
« Reply #7 on: 01 September 2013, 15:48 »
Get VAG COM plugged into the car, see what codes come up
Offline M.sheldon23
« Reply #8 on: 01 September 2013, 15:50 »
Will it need to go to dealers to be plugged in? Vag com?
Offline Scott D
« Reply #9 on: 01 September 2013, 16:34 »
ask on here will be someone local with a laptop who can scan car for faults
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
