Author Topic: Mk6 Golf R brakes on a Mk5 GTI  (Read 23579 times)
Offline th3_f15t
Re: Mk6 Golf R brakes on a Mk5 GTI
« Reply #10 on: 02 September 2013, 15:14 »
Then these may be getting fitted rather much sooner than I first thought the would be! Yay!
Moving over to Flickr, sorry for the broken picture links!
Offline th3_f15t
« Reply #11 on: 04 September 2013, 17:06 »
Does anyone have the part numbers for the caliper bolts, or a link to where I can buy some? Searching around but I've not found any yet... :(
Offline th3_f15t
« Reply #12 on: 06 September 2013, 15:18 »
And also braided stainless steel brake lines, these seem to be no-where I've looked so far.
Offline nadlad
  • Building Surveyor MRICS
« Reply #13 on: 06 September 2013, 21:55 »
Hi
I have a full set of r32/s3 brakes front and rear including discs and pads and dust shields ready to bolt on from a low mileage r32, £550ono delivered 07746888846
<<<Big Build Thread>>>
Offline th3_f15t
« Reply #14 on: 06 September 2013, 22:46 »
Thanks for the offer, but I've just bought a front brake set up from a Golf R. Just need the final bolts as the old carrier ones can not be re-used.
Out of interest, what's the difference in size between the GTI and the R32/R rear disc dimensions?
Offline sustanon400
« Reply #15 on: 07 September 2013, 08:02 »
Lets see some pics when you get the brakes fitted dude  :whistle:
Don't forget I've got the huge golf R intercooler going very cheap , would be awesome on a mk5 gti  :evil: £100!!!!!!
2012 mk6 golf "R"
Porsche 996 turbo cab (510bhp)
Offline th3_f15t
« Reply #16 on: 07 September 2013, 08:08 »
Of course I shall show pictures! Keep an eye on my project thread (link is in my signature). Once I know exactly which bolts I need and where to get them from it shall be scheduled in for a re-fit. I still can't believe the difference in size between my stock GTI calipers and the R calipers!
Offline sustanon400
« Reply #17 on: 07 September 2013, 08:29 »
They are great brakes , worked a treat on my golf R , main reason I changed to VWR kit was the 27 kg weight saving - it all helps on the R as its a heavy beast  :undecided:
2012 mk6 golf "R"
Offline th3_f15t
« Reply #18 on: 19 September 2013, 21:37 »
In terms of stainless steel brake lines, could I buy Mk5 R32 front lines and fittings or do I need to specifically buy Mk6 Golf R lines?
Offline Beddie
« Reply #19 on: 19 September 2013, 22:00 »
Yes all the lines for the mk5 R32/ Audi S3 / Leon Cupra / Mk6 R are the same  :smiley:
I can recommend the HEL kit, think the part number is 'VAG-10' iirc, this kit will also do away with the hard lines on the caliper as the HEL hose has an angled banjo bolt straight onto the caliper, usually around £50 for the front kit  :smiley:
Carbon Grey ED35
