Author Topic: Forge Twintercooler  (Read 3581 times)
Offline jhunter_83
Forge Twintercooler
« on: 29 August 2013, 12:52 »
Just looking for people's view on the above and have anyone got one fitted?
Also, is it worth buying over getting another intercooler?
Thanks
2010 Silver Golf GTi 5 Door, Poverty spec wheels, RCD510 Bluetooth and DAB, Pagid Discs and Tarox Strada Pads
Offline LukeRhino
Re: Forge Twintercooler
« Reply #1 on: 29 August 2013, 13:35 »
After getting REVO stage 2 dont last week I too am interested in finding out peoples opinions
Mk6 gti, REVO Stage 2, TBE, Filter, Wind Deflectors.
Offline pryda
« Reply #2 on: 29 August 2013, 15:41 »
I think a new clutch should be top of your shopping list mate
2009 MK6 GTi, Candy White 3dr, Stage 1 Revo, Milltek cat back, H&R SuperSport, RNS510, OSRAM kit
Unphased - NorthWest German/VAG/Retro Meet
Every 3rd Thursday Of The Month
http://www.un-phased.co.uk/
Offline LukeRhino
« Reply #3 on: 29 August 2013, 15:52 »
Clutch seems to be fine now, not had any other issues with it, ill upgrade as soon as theres any slippage. theres enough money in the pot for it!
Offline jhunter_83
« Reply #4 on: 29 August 2013, 16:17 »
Although I'm bluefin stage 1 when I go stage 2 I will be going apr as there maps don't seem to be as severe as revo maps.
I plan not to change my clutch until k04
Offline Neil gti
« Reply #5 on: 30 August 2013, 21:28 »
Alex at AKS really rates the THS intercooler over the twintercooler option,
I have fitted the Forge intercooler and Twintercooler bit of overkill I think but I certainly don't get any heat soak   :grin: I only fitted them both because I got them very cheap
You can see mine through the front lower grill
« Last Edit: 30 August 2013, 21:36 by Neil gti »
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline jhunter_83
« Reply #6 on: 30 August 2013, 22:42 »
How do you find the k04 as a everyday driver? I am 90% sure I am going down that route.
Offline Neil gti
« Reply #7 on: 31 August 2013, 06:29 »
I don't see much difference in the K04 over the IHI turbo when driving normally, apart from the boost comes in a little later and the Turbo is noisier over standard form but not in a bad way,  mine is DSG tho so that might make a difference in drivability over a manual box,
The manual box might feel a little laggy low down ? But it's something you adjust to and soon get use to it,
When out on the open road it's a different story, as soon as the pedal hits the floor all hell breaks loose and it just pulls n pulls were as the IHI soon runs out of puff up in the rev range, it's not stupidly torque steering all over the place it's very composed if you drive it correctly and control the power with your right foot it's great ! Or if you want you can drive like a cock and wheelspin it in 3rd gear you can do,
Couple the K04 with the Powervalve BCS and on full chat the sound is incredible, it is by far the best exhaust that I've ever had on a car and I've had a few lol
Loving the 7R
Offline jhunter_83
« Reply #8 on: 31 August 2013, 08:03 »
Would you recommend anything other than exhaust, and cooler before going k04?
Offline Neil gti
« Reply #9 on: 31 August 2013, 10:16 »
That's all you need really as you've already got a CIA
If you wanted max benefits a Revo throttle pipe and Neuspeed discharge pipe wouldn't go a miss  :smiley:
Loving the 7R
