Author Topic: Speedo cable drive - red or white?  (Read 1815 times)
Offline dadrathers
« on: 28 August 2013, 22:07 »
Tried the search but conflicting answers.
1991 GTI 8v PB 5-speed manual RHD 140 MPH clocks.
ETKA lists both but does not say anything about specific application.
Vote now!
Thanks.
Offline Craigwilson
Re: Speedo cable drive - red or white?
« Reply #1 on: 28 August 2013, 22:19 »
I have 140 clocks on a chb box with the white speedo and and the speed is perfect
Offline Mr Blue
« Reply #2 on: 28 August 2013, 22:23 »
IIRC red was 120 and 160
Offline jezza16v
« Reply #3 on: 29 August 2013, 15:47 »
The speedo drive pinion has to match the diameter and tooth pitch of the drive in the gearbox, it is a myth that you can fit different coloured pinions with different numbers of teeth into a box to adjust the reading on the speedo. Our 8v with standard gearbox has a red drive pinion and has had 120 & 160 clocks in without issue. You can fit a different colour pinion but it must have the same diameter and number of teeth and pitch as the standard red one or it will get mashed up.
Offline Gambit
« Reply #4 on: 30 August 2013, 14:35 »
its no myth
120 & 160mph clocks work off the red drive
140mph clocks work off the white drive
either will work in any 020 gearbox
