Author Topic: silicone reducer for vr6 to agu  (Read 2620 times)
Offline sharki786
  • GOT BOOST??
« on: 28 August 2013, 07:12 »
I have a s2k filter and the forge k03 (s) tip. Which is the best out of these to use?
http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_nkw=76-51mm+Straight+Reducer+Silicone+Hose&_sop=15
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
Re: silicone reducer for vr6 to agu
« Reply #1 on: 30 August 2013, 07:10 »
Anyone?
*****MK4 GTI T*****
Offline Nino
« Reply #2 on: 30 August 2013, 07:34 »
You mean the filter to the MAF?
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 30 August 2013, 14:02 »
Ye was thinking about sticking the vr maf on with the s2k filter :evil:
*****MK4 GTI T*****
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 01 September 2013, 15:53 »
don't fit it unless it's mapped to suit
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 01 September 2013, 20:40 »
What would happen if i did?
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 02 October 2013, 12:02 »
Bump.
I will just use the housing as someone has said before you can just use the casing so no need for a reducer.
*****MK4 GTI T*****
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 02 October 2013, 22:24 »
If you fit it before it's mapped you will throw all sorts of fuelling into your engine leading to loss of power and worst case bore wash. The VR6 MAF element itself is said to be exactly the same as the AGU version.
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 03 October 2013, 10:46 »
Oh ok i wont bother lol. Il just fit the filter on with standard maf on?
*****MK4 GTI T*****
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 03 October 2013, 11:19 »
Also another point is if you enlarge the MAF you'll need bigger injectors
