Author Topic: k300 turbo???  (Read 3802 times)
Offline sharki786
  • GOT BOOST??
k300 turbo???
« on: 27 August 2013, 15:06 »
Been speaking with beach buggy turbos. As i shouldav got a k03s on sunday but guy sold it a day before. Anyway been speaking with littco? About which would benefit me. A hybrid k03 or a hybrir k03s? Im after the 300bhp mark and he said go for the k300. Now what the hell is the k300? Which car does it come from and whats the max power i can achieve from them? Is it a garret turbo?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Scott D
Re: k300 turbo???
« Reply #1 on: 27 August 2013, 15:16 »
IIRC it is a K03 based hybrid that's good for a genuine 300bhp with the correct supporting mods.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline ReDBull
Re: k300 turbo???
« Reply #2 on: 27 August 2013, 16:10 »
Not sure but I no a man who does  :wink:
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline littco
Re: k300 turbo???
« Reply #3 on: 27 August 2013, 16:17 »
K300 is the name I gave to the 300bhp k03 hybrid
The k03 and k03s turbine housings are identical but not needed as I can supply brand new off the shelf units. Ie crack free:-)
Offline mar_k
Re: k300 turbo???
« Reply #4 on: 27 August 2013, 16:39 »
What do they retail on exchange basis and also the new ones?
Offline sharki786
  • GOT BOOST??
Re: k300 turbo???
« Reply #5 on: 27 August 2013, 18:44 »
That was you i was messaging on fb? Beach buggy turbos? :lipsrsealed:
*****MK4 GTI T*****
Offline mar_k
Re: k300 turbo???
« Reply #6 on: 27 August 2013, 20:50 »
Littco is BeachBuggy,
Offline sharki786
  • GOT BOOST??
Re: k300 turbo???
« Reply #7 on: 27 August 2013, 22:03 »
Sweeeeet
*****MK4 GTI T*****
