Author Topic: INSTALL FLY BY WIRE ON MK3  (Read 7877 times)
Offline tshirt2k
  • Been there...Done that...
Re: INSTALL FLY BY WIRE ON MK3
« Reply #20 on: 27 September 2013, 11:10 »
fatherless son, beaten to it. :grin:
Least you have the correct way of thinking.  :wink:
Mk3 ABF 16VT Megasquirt V3
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #21 on: 27 September 2013, 11:14 »
Damon is just trying to be clever but in reality he is like a fish out if water
Just stop making even more of a fool of yourself old fella
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Diamond Hell
  • Opinions я Us
« Reply #22 on: 27 September 2013, 11:17 »
As if by magic Brad brings in some people who he knows who know far more than he does.
Surely using your initials for your business is a bit off when you're just the mouth and polisher?  :grin:
Offline F17BAD
« Reply #23 on: 27 September 2013, 11:24 »
Lol whatever
U asked why it wouldn't work and I told you
Deal with it..
Next :grin:
Offline molegti
« Reply #24 on: 27 September 2013, 13:02 »
If the resistance range is wrong (I assuming you mean its log) can the pot not be changed for either one from a MK4 or one or something else from Maplin/Farell etc. I would have thought the value would be printed on it.
Just thinking of other options if fabrication of a hybrid pedal box isn't an option.
Offline F17BAD
« Reply #25 on: 27 September 2013, 14:24 »
No mate
If said person can't do the job then they should not be trying in the first place..
Really is not that hard to use the correct pedal and loom.
You keep the original pedal box anyhow, the accelerator pedal is the only one that needs To be changed
No need to remove the exciting pedal box
Mk2 u use the corrado item so while its out u could modify
Offline molegti
« Reply #26 on: 27 September 2013, 15:27 »
Fair enough I've read your build thread so I'm aware you've done it.  Cant say I've even looked at the set up on a MK3 or 4 just trying to suggest an alternative route to investigate.
Not sure about pedal boxes being interesting though.... :)
Offline F17BAD
« Reply #27 on: 27 September 2013, 16:23 »
Yea mate done it many times this is why I know.
I can see why problem would ask the questions
Certain people don't like to be wrong tho, which is daft
Because if they just stopped been a wan ker they might actually learn something, and that's not aimed
At u dude  :smiley:
