Author Topic: INSTALL FLY BY WIRE ON MK3  (Read 7855 times)
Offline Screech16v
  • MK3 20vt AGU
Re: INSTALL FLY BY WIRE ON MK3
« Reply #10 on: 18 September 2013, 22:36 »
 :laugh: here we go!
Offline Diamond Hell
  • Opinions я Us
« Reply #11 on: 24 September 2013, 20:04 »
Tell us why then, big boy.
Offline tweed
« Reply #12 on: 24 September 2013, 21:16 »
Tried and failed  :grin:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #13 on: 26 September 2013, 12:13 »
The resistance is wrong. This is critical on the 20vt
Even the mk4 diesel won't work with a mk4 20vt
Not no ordinary GTI....
www.mixcloud.com/kells/
  • Opinions я Us
« Reply #14 on: 26 September 2013, 23:49 »
So install an inline resistor to bring it right.
It's not rocket science.  :grin:
Offline F17BAD
« Reply #15 on: 27 September 2013, 10:18 »
Now your just been silly..
If you want to do the job the correct way, then use the correct pedal
And don't cut corners.
 :smiley:
  • Opinions я Us
« Reply #16 on: 27 September 2013, 10:53 »
It's not being silly - insert resistor, bring signal in line, use the part that bolts up.
There is more than one way to skin a cat, nipper.
Offline tshirt2k
  • Been there...Done that...
« Reply #17 on: 27 September 2013, 11:04 »
A resistor won't change a range of resistance will it?   :whistle:
That will be a shift of resistance range and a bit if a bodge.
Mk3 ABF 16VT Megasquirt V3
Offline Bellend
« Reply #18 on: 27 September 2013, 11:05 »
The trouble with them is the range is different.
It's not just 1k ohms less across the board, the entire sweep is different. No idea how to put it. "Range ratio" is the only thing I can think of. :grin:
Where all my moneys went.
Offline Bellend
« Reply #19 on: 27 September 2013, 11:05 »
Bastard, beaten to it. :grin:
