Author Topic: Footwell light whilst driving  (Read 14590 times)
Offline Gaz2559
« on: 26 August 2013, 14:30 »
Hi.
I have a 2009 gt tdi with luxury and convenience pack. Is it possible to have the footwell lights on whilst driving?  My mate has a 2011 gtd and his footwell lights are on whilst driving.
Amy help would be appreciate cheers!
Gaz
Offline Ginge 35Edition
Re: Footwell light whilst driving
« Reply #1 on: 26 August 2013, 15:49 »
It's altered by the multi function computer on the GTD and GTi but not sure about the GT? Have you had a play about with these settings?
Offline Gaz2559
« Reply #2 on: 26 August 2013, 16:32 »
I have yeah, upped it to 100% but not sure if that's just for when the doors open. I will check what it says on the options and let you know. Seems weird that only Gtis and gtd can do it tho!?
Ta
Offline dubber36
« Reply #3 on: 26 August 2013, 18:58 »
Mine are on when driving.
Offline Gaz2559
« Reply #4 on: 26 August 2013, 22:24 »
Is yours a GTI or GTD?
Offline Jimble
« Reply #5 on: 26 August 2013, 22:39 »
It's the GT in his sig mate. ;)
Offline dubber36
« Reply #6 on: 27 August 2013, 18:11 »
Yeah, it's a GT. The footwell lights come on with the ignition.
Offline Gaz2559
« Reply #7 on: 27 August 2013, 20:41 »
Ah yes the signature, stupid me!
Just checked the MFD and footwell lights are on at 100% but nothing when driving. I think I may need a dash update from VW? If I can be bothered that is!
Does ur Gt show you your tyre pressure, or does it just indicate when it is below a certain PSi? Just wondering as my boss has a new passat and his systems states the pressure on each tyre. I thought mine had that but believe I just have a warning indicator? Again not essential, just would like things to work if I have them.
Cheers.
Offline dubber36
« Reply #8 on: 28 August 2013, 09:00 »
My Golf just has a TPMS warning light in the dash and a reset button in the glovebox. It's a bit half assed really as is works on wheels speed sensors. If a tyre deflates, its overall rolling radius reduces, therefore the wheel speeds up to keep up with the other 3.
I also have a 2011 Passat, and that has a "proper" tyre pressure monitoring with sensors in each tyre valve and a live data display on the instrument cluster.
Offline dubber36
« Reply #9 on: 28 August 2013, 19:32 »
Going back on my earlier statement, the footwell lights come on at 100% brightness with the interior lights, then dim down to the preset brightness when the ignition is turned on.
