Author Topic: Car lunges when jabbing Brake Pedal  (Read 861 times)
Offline Zayd
« on: 26 August 2013, 12:29 »
I seem to have the same symptoms as I had about 18 months ago and since fitting a cheaper front wishbone, than I would normally have acquired.
If I jab the brake pedal the car will lunge slightly forward and I previously worked this out to be a worn NSF wishbone rear bush.  I had the MOT done last week and the guy said the same bush had a little play in it.  I usually only fit OEM parts, but on this one occasion I left it to the mechanic to order in and it was a cheaper product.
The morale of the story is, fit cheap and you'll be fitting twice!
Turbocharged and liking it...
Offline mar_k
Re: Car lunges when jabbing Brake Pedal
« Reply #1 on: 26 August 2013, 19:41 »
Yep, I did the same when I had my 2.0 mk4. I fitted pattern arms and withing 11mths the complete rear bush was shot.
Hardly anything left of it. I went poly after that.
