Author Topic: 6 speed or 5 speed gearbox ??? which is better ???  (Read 1185 times)
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
« on: 25 August 2013, 23:54 »
Hi there im running a 300+ bhp mk4 Golf and have a 5 speed gear box currently fitted but would a 6 speed gear box be any better ???
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
Offline barrym381
Re: 6 speed or 5 speed gearbox ??? which is better ???
« Reply #1 on: 26 August 2013, 00:08 »
mine is great for motorway trips thats about all i think  :smiley:
Offline mar_k
« Reply #2 on: 26 August 2013, 12:06 »
I think you will benefit from the 6-speed, Having driven my mates Mk4 1.8t on a stage 1 map it all ways
felt like it needed an extra gear.
My LCR is 6 speed and feels far better,
Offline mcgee9t2
« Reply #3 on: 26 August 2013, 12:09 »
if I was going to go through the trouble of swapping gear box personally I wouldn't be putting in a 6 speed box, id be changing all the gears for ones with better ratios.
iirc 1-4 is the same in a 5 speed and 6 speed.
then on the 6 speed box the 5th gear is a different ratio and 6th is a different ratio...
but I could be wrong..
Offline WadGTI
  • Golf GTI'er
« Reply #4 on: 28 August 2013, 12:57 »
I have a 6 speed and have notcied when going into red from 3rd into 4th, when you change gear into 4th and 5th, it drops right into the max power band or just in the start as you up the gears.
Offline gavgtiturbo
« Reply #5 on: 31 August 2013, 14:08 »
I liked the 5 speed for around town but on the motorway I always felt like it needed 6
