Author Topic: Wind deflectors!?  (Read 1791 times)
Offline Jay-White-Gti
Wind deflectors!?
« on: 24 August 2013, 16:41 »
Anyone know where the best place would be to buy wind deflectors from?  Found some on amazon for about 30 pound but not sure if will be good quality or not!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wind deflectors!?
« Reply #1 on: 24 August 2013, 16:43 »
as long as they are made by Heko you will be fine
Offline mcgee9t2
« Reply #2 on: 24 August 2013, 17:50 »
heko ones on ebay for about 24 quid last time ichecked.
bit of a waste of time imo though. had three sets, one got kniked while I was in town, one se got kniked at ultimate dubs and one got kniked at edition....
« Reply #3 on: 24 August 2013, 18:03 »
wow that's u lucky I might just get some see how it's goes of they get knicked wont bother again :)
Offline Nino
« Reply #4 on: 24 August 2013, 19:27 »
Shouldn't be able to steal them if fitted correctly with the clips. And if the windows are up
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline mcgee9t2
« Reply #5 on: 24 August 2013, 22:10 »
first time on my old car had all clips in...
second time on new car had all clips in, but one window was left down a cm. other side was fully up.
third time had the clips from the second time and the new clips in... so two sets of clips...and the window was up.
there not that hard to nik when the clips are in... the first time, they only niked 1, so I tried to take the rest out with out taking the clips out, didn't take long at all,even with window up...
Offline Nino
« Reply #6 on: 25 August 2013, 10:55 »
Baastards
Offline navmk4gti
« Reply #7 on: 26 August 2013, 13:43 »
 :shocked:
And i was just going to order a set to hmmmm
Offline damien010685
« Reply #8 on: 26 August 2013, 15:06 »
Well on my 3 door nav I can't pull them out at all with the windows up and I have had mine for 2 yrs and not a problem stops rain getting in and I think they look good
Offline davemk4
« Reply #9 on: 26 August 2013, 15:12 »
got team hekos on mine they are fine apart form they drop slightly over time so just bought some new clips to put extra ones in
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
