Author Topic: Throttle body clean AGG?  (Read 6887 times)
Offline GOLF-MK3-GTI
« on: 24 August 2013, 16:00 »
I've got a MK3 GTI it's an 8V, AGG engine code, I noticed today that the revs were kinda fluctuating, so I'm thinking of cleaning the throttle body aswell as new breather pipes.
My question is does throttle body on the AGG need aligning? I know that on the ADY engine code it does, but not sure about the AGG throttle body?
Also what products would you recommend to use for cleaning?
Cars been in family for last 5 years, and it's never been done before, so it's a must I rekon!
Re: Throttle body clean AGG?
« Reply #1 on: 24 August 2013, 16:01 »
It cut out today when I dipped clutch in to change gear. But it started up staright away.
Offline MickP mk3
« Reply #2 on: 24 August 2013, 17:12 »
I removed the TB for cleaning on my AGG and just lined it back up by using marks made previously by the Allen key bolts and it ran fine. I also removed the water pipes in and out of the TB, stopping hot water running through it, to cool the air temp a bit.
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #3 on: 24 August 2013, 17:39 »
Sure its not a duff maf causing your problems?
« Reply #4 on: 24 August 2013, 17:42 »
it can't be the maf. It's got a brandnew maf bought from VW 2 years ago.
« Reply #5 on: 24 August 2013, 17:43 »
hmm, where have you routed the pipes now?
Offline Rossco250
« Reply #6 on: 24 August 2013, 17:46 »
I think somebody should do a guide on this :nerd: I'm thinking of doing it too, but not sure how!  :huh:
VW BUSH
« Reply #7 on: 24 August 2013, 17:58 »
loop them together, but makes no noticeable difference imo.
I use FE10 and a tooth brush to clean tb, take it off once in while but no need to do it all the time as gasket can suffer.
« Last Edit: 24 August 2013, 18:00 by VW BUSH »
« Reply #8 on: 24 August 2013, 18:21 »
I'm gonna buy a new gasket so it's ok. Plus it's not been done in for last 5 years and it's only started to fluctuate now. So I'm 100% sure it needs cleaning.
Offline MickP mk3
« Reply #9 on: 24 August 2013, 19:56 »
if i remember right, the water pipe comes out of the header tank, into the TB, then out into the cylinder head somewhere near the front of the engine ( i think, without looking). So just delete the pipe to the TB, and go from the header tank to the cylinder head. I didn't notice any real difference, it was the same mod for the mazda 323f BA.
« Last Edit: 24 August 2013, 20:00 by MickP mk3 »
