Author Topic: Mk4 1.8t agu shaking/wobbling  (Read 4061 times)
Offline dannydubs
  • mk2 gti,mk3 wagon,mk5gti
« on: 24 August 2013, 15:24 »
Need a bit of help I've got a agu mk4 1.8t
At around 50+mph the whole car shakes/wobbles feels like its moving side to side it's not actually moving on the road tho just a shake
It stops soon as I come off the power so only under load doesn't do it if coasting
I've tryed different wheels/tires and I've given the engine a good pull/push/tuck and doesn't seem to have any movement there
Any ideas what it could be?
.....the project.........
Offline Rhyso
Re: Mk4 1.8t agu shaking/wobbling
« Reply #1 on: 24 August 2013, 17:01 »
Wherls balanced?
Wheel bearings?
Offline dannydubs
« Reply #2 on: 24 August 2013, 17:52 »
I've tried different wheels and tyres so not
That's
Can't be bearings as would do it if I was coasting or not
Offline Rhyso
« Reply #3 on: 24 August 2013, 18:27 »
Engine misfiring??
Offline dannydubs
« Reply #4 on: 24 August 2013, 20:27 »
Nope engines not misfiring
Offline Rhyso
« Reply #5 on: 24 August 2013, 21:32 »
Checked your wishbone bushes? Track rod ends?
Offline barrym381
« Reply #6 on: 24 August 2013, 21:53 »
flywheel maybe  :undecided:
Offline dannydubs
« Reply #7 on: 24 August 2013, 22:02 »
No but I'd say its not that as again it would do it all the time
Offline Ben@VWH
« Reply #8 on: 27 August 2013, 12:10 »
Sounds like typical inner cv joint failure. Get the car in the air and check them for excess play. Your car will have either early 100mm cv's (I can help with these) or the later 108mm joints, the 108mm joints are prone to failure.  :smiley:
Offline dannydubs
« Reply #9 on: 28 August 2013, 12:44 »
Ok gona check this evening my car being a t plate id say its the
Early type
