Author Topic: thickness of discs  (Read 1623 times)
Offline leigh3292
thickness of discs
« on: 24 August 2013, 10:10 »
Im wondering if anyone can help me,
ive got a mk3 golf gti 8v and recently my abs light came on so i took off a wheel and had a look at the brakes,
pads seem low but also the discs are getting thin aswell , does anyone know the thickness that they should roughly be and if there is anything else i should check if the abs light comes on.
cheers :-)
VW BUSH
Re: thickness of discs
« Reply #1 on: 24 August 2013, 12:18 »
Scan it for faults first.
You will most likely have a sensor out, my advice is to replace them in in pairs
Disc thickness will not affect abs.
If they look worn have a heavy lip or have uneven wear then change them regardless.
VW BUSH
« Reply #2 on: 24 August 2013, 18:05 »
Think minimum thickness is 19mm and 7mm F/R
Offline leigh3292
« Reply #3 on: 25 August 2013, 15:01 »
Thank you people for your help :-)
