Author Topic: mk 2 abf  (Read 7151 times)
Offline pedr088
mk 2 abf
« on: 22 August 2013, 18:56 »
Thinking of putting an abf into the mk 2 keeping kjet is it case just buying block and head and bolting the kjet stuff to it.
Also what manifold did people use
Offline Neo Badness
  • Feet are for pedals
Re: mk 2 abf
« Reply #1 on: 22 August 2013, 19:32 »
Without being snide, this has been covered in some depth previously. Personally I would say buy a donor car complete and fit the whole EFi setup.
Toyotec has made a very good guide.
http://www.clubgti.com/showthread.php?133418-Toyotec-s-How-to-install-an-ABF-engine-in-your-Mk2-Golf-Revisit-of-KJet-car-180610
Re: mk 2 abf
« Reply #2 on: 23 August 2013, 13:40 »
Better to fit the complete setup.
Offline mk2bal
Re: mk 2 abf
« Reply #3 on: 26 August 2013, 12:50 »
I disagree. My Kjet abf made 160bhp and was spot on for years. The Kjet is the only thing that was good! H/g went, crank keyway failed etc etc but the Kjet side of things was fine. If you are running a fine Kjet setup then just drop the engine in, it's a weekends work to do a nice job of it. Wiring and fuelling swap etc just isn't worth it for the marginal gains. I was bored within 5 minutes of it anyways, so now it's 223bhp from an agu k03s.
Offline Simeon
Re: mk 2 abf
« Reply #4 on: 29 August 2013, 23:41 »
So does an abf on proper management, except it also returns 40mpg and doesn't need setting up every 5 minutes.  Fit it properly or don't bother in my opinion. Easy swap.
Offline weazgti
Re: mk 2 abf
« Reply #5 on: 30 August 2013, 07:54 »
It's also nice to have an old shed that runs spot on all the time and always starts instantly.
Rather than the revs plummeting at junctions and cutting out when cold
Offline Gambit
Re: mk 2 abf
« Reply #6 on: 30 August 2013, 14:31 »
easiest way is to bolt the abf bottom end to existing k-jet head.
anybody who complains about kjet just cant set them up really :p
Offline gazareth
Re: mk 2 abf
« Reply #7 on: 30 August 2013, 22:53 »
yeah and im sure an abf management wouldn't be 100% reliable forever more anyway. I mean how many k jet equipped cars do you see stranded at the roadside?
Offline molegti
Re: mk 2 abf
« Reply #8 on: 30 August 2013, 23:46 »
But how many k jet equipped cars do you see? :smiley:
I suppose it depends on what you have to start with I'm midway an abf conversion on a a late ce1 8v digi and I'm using the abf management. If my car had been a 16v I'm not sure i wouldn't have retained k jet.
VW BUSH
Re: mk 2 abf
« Reply #9 on: 31 August 2013, 13:21 »
Kjet was fitted to fords from about 83 to 91, onion XR2/3 etc etc. With a gas analyser and some patience can be set up to be quite effective, although efi is much better and reliable for longer periods.
