Author Topic: Where can i get R32 clocks coded to my AGU engine im in the Northwest ???  (Read 2252 times)
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
Hi there fellow V dubbers
Can anyone tell me where i can get my R32 clock coded to my AGU engine im in Warrington ( Northwest )
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
lol I could have done it before you bought it
Offline mcgee9t2
VW
Garage with VAGCOM
or look for the nearest person to you in this thread and offer them a few beer tokens for there services.
http://www.golfgtiforum.co.uk/index.php?topic=87936.0
Hi dude, thanks for letting me no, think ive managed to find someone in Manchester Wazzer, take care mate
VW
Garage with VAGCOM
Thanks for that info ive found someone in Manchester on there to sort it  :smiley:
Offline Scott D
Is it a fella called Dave doing the coding?
Got some R32 clocks here gathering dust - will get them fitted one day  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
its a guy called chrisr103 on here mate, ive messaged him but still not go back to me ill let you no how i go on
Offline xtetx
Chris doesn't do it anymore from what ive heard.
I've got Daves contact. Based in Stockport. Knows his stuff!
Pm me brothers
« Last Edit: 23 August 2013, 08:07 by xtetx »
Offline xtetx
Matty I've text you his number mate
